Phase 6 Glider KIt
7 years 5 months ago #15607 by Dave Rogers
Replied by Dave Rogers on topic Phase 6 Glider KIt
My wing is like David’s. One servo in centre. Easy peasy.
7 years 5 months ago - 7 years 5 months ago #15625 by Phil Ford
Replied by Phil Ford on topic Phase 6 Glider KIt
Chris, have took all the Bits out of the box. Wings veneered and cut out centrally for a mini servo. (Although they still supply the torque rod and nylon bearings for centre servo, although the central recess is longer there. Torque rod is now recommended to use for optional flaps. Fuselage sides are two piece still and CNC cut using liteply. :( Might follow what others have done that I read recently and that is make up one piece sides in birch ply using the original sides as a template. Fuselage formers are laser cut ply and no longer require balsa backing.
Last edit: 7 years 5 months ago by Phil Ford.
7 years 5 months ago #15631 by AlanF
Replied by AlanF on topic Phase 6 Glider KIt
Dave Rogers wrote: My wing is like David’s. One servo in centre. Easy peasy.
Dave, I can't remember, was yours the fully symmetrical wing version?
7 years 5 months ago #15643 by Dave Rogers
Yes fully symmetrical. Also my wing does have 2 servos but both mounted one behind the other in the centre of the wing
7 years 5 months ago #15644 by AlanF
Cheers Dave, yours flew well enough the other week, that's the one I would be tempted with.
7 years 5 months ago - 7 years 5 months ago #15645 by Phil Ford
Dave Rogers wrote: Yes fully symmetrical. Also my wing does have 2 servos but both mounted one behind the other in the centre of the wing
That must be tight fit. You have full length ailerons? I'll have to look at that. :huh:
