Mini LecRoo
  • 4Pedalsfly
6 years 5 months ago #18863 by 4Pedalsfly
Replied by 4Pedalsfly on topic Mini LecRoo
Last picture - Fuselage covered, now onto the wing -watch this space.
6 years 5 months ago #18864 by kevinross
Replied by kevinross on topic Mini LecRoo
good to keep busy during the current weather Colin. Id love to be sticking balsa but having to do emergency lathe maintenance
6 years 5 months ago - 6 years 5 months ago #18865 by Brian
Replied by Brian on topic Mini LecRoo
Colin, as instructed in the Feb 9 post,I watched the space. Nothing happened so I gave up after two hours. Nipped down to the shed as the rain had stopped, glued and pinned the pieces of balsa and ply that I'd prepared on Saturday. I found the envelope that the Wot Knot plan came in. The postmark was 2006. The build started that year, and at the rate its going now, I'll not be finished this year, not unless I can find a fresh packet of enthusiasm, the old one ran out sometime last year.
Last edit: 6 years 5 months ago by Brian.
  • 4Pedalsfly
6 years 2 months ago #19685 by 4Pedalsfly
At long last the model is finally ready for her maiden flight, pics attached.
I've fitted a tow hook so I'm planning a bungee launch off the ramp for the maiden flight,
then hand launches for subsequent flights.
Model weighs 2 1/4 Ibs, current draw of 50A giving 550W = 248 W per Ib with a wing loading
of 11 ozs per sq ft, so ample power with a light wing loading.
Motor is EFlite inrunner 3,200 kv turning a 6x4 prop, battery 3S 2,200 LiPo
Just waiting for a suitable weather day and off she will go.
6 years 2 months ago #19687 by MikeSeale
Replied by MikeSeale on topic Mini LecRoo
Looking good.
6 years 2 months ago #19688 by DaveBright
Replied by DaveBright on topic Mini LecRoo
Nice Colin. Good luck
