Mini LecRoo
10 Feb 2019 10:26 - 10 Feb 2019 10:28 #18865 by Brian
Replied by Brian on topic Mini LecRoo
Colin, as instructed in the Feb 9 post,I watched the space. Nothing happened so I gave up after two hours. Nipped down to the shed as the rain had stopped, glued and pinned the pieces of balsa and ply that I'd prepared on Saturday. I found the envelope that the Wot Knot plan came in. The postmark was 2006. The build started that year, and at the rate its going now, I'll not be finished this year, not unless I can find a fresh packet of enthusiasm, the old one ran out sometime last year.
Last edit: 10 Feb 2019 10:28 by Brian.
  • 4Pedalsfly
29 May 2019 23:00 #19685 by 4Pedalsfly
Replied by 4Pedalsfly on topic Mini LecRoo
At long last the model is finally ready for her maiden flight, pics attached.
I've fitted a tow hook so I'm planning a bungee launch off the ramp for the maiden flight,
then hand launches for subsequent flights.
Model weighs 2 1/4 Ibs, current draw of 50A giving 550W = 248 W per Ib with a wing loading
of 11 ozs per sq ft, so ample power with a light wing loading.
Motor is EFlite inrunner 3,200 kv turning a 6x4 prop, battery 3S 2,200 LiPo
Just waiting for a suitable weather day and off she will go.
30 May 2019 08:02 #19687 by MikeSeale
Replied by MikeSeale on topic Mini LecRoo
Looking good.
30 May 2019 08:26 #19688 by DaveBright
Replied by DaveBright on topic Mini LecRoo
Nice Colin. Good luck
30 May 2019 09:53 #19692 by Phil Ford
Replied by Phil Ford on topic Mini LecRoo
Let me know your plans for a maiden and I will bring up the launch gear. This thing might be a little faster than my Super Wing.:blink:
PS: Those 2200mah 3 cells would also fit nicely in a Sabre F86 ;)
  • 4Pedalsfly
30 May 2019 17:53 #19697 by 4Pedalsfly
Thanks Phil - Will post when I'm going - I've also have a Ripmax " Mustang " to maiden so need a good chucker for that too.
Still thinking about the MIG 15 but I'm already being told I have too many models, my 3S 2,200 LiPo's are 30/40C so may need
to upgrade since I'm pulling 23 C at 50 Amps !! - would then be ideal for a MIG.
30 May 2019 18:40 #19698 by Brian
Colin, it isn't a case of "too many models", it simply boils down to the fact that you haven't got enough space for the models you have/want.
30 May 2019 19:06 #19699 by Phil Ford
Brian wrote: Colin, it isn't a case of "too many models", it simply boils down to the fact that you haven't got enough space for the models you have/want.
Exactement! Vous avez besoin d'un plus grand garage
30 May 2019 19:27 - 30 May 2019 19:28 #19700 by Brian
Mais non! J'ai un petit maison seulement.
Last edit: 30 May 2019 19:28 by Brian.
30 May 2019 22:06 #19701 by Phil Ford
Brian wrote: Mais non! J'ai un petit maison seulement.
Non, je voulais dire que Colin a besoin d'un plus grand garage :blink:
