Scratch Building a Mercury Marlin
7 years 5 months ago - 7 years 5 months ago #15996 by Brian
Replied by Brian on topic Scratch Building a Mercury Marlin
Finally, after a long and fiddly business cutting slots in the ribs for the control wires, and drilling the tips for leadout tubes, the wing is at last all in one piece. If there is a "next time", I'll slot the ribs before I build the wing! The tail plane and elevator went together without any trouble. I offered the wing up to the fuselage, fortunately it looks as though it'll fit without any adjustments
Last edit: 7 years 5 months ago by Phil Ford.
7 years 5 months ago - 7 years 5 months ago #15997 by Brian
Here's the Elfin 1.8 just as it was in the box of "bits" I was given. The compression is good and it turns over freely. Unfortunately the exterior appearance is marred by assorted marks from plumbers wrenches and suchlike vandalism. The prop has a "frog" label on the back face, it claims to be a "nylon airscrew". I think it might have been intended to be crash proof, I remember nylon props, but I don't remember them being as flexible as this one. Perhaps its a function of age, if so, I wonder why I'm so stiff these days?
7 years 5 months ago #16029 by Brian
Planking gives the model a strong, light structure. I was surprised how easy it has turned out to be. Using aliphatic resin is clean, but I do miss the smell of Britfix 66. However, its nice to have clean fingers without sitting for ages and nibbling at bits of dried balsa cement.
7 years 5 months ago #16031 by Phil Ford
Replied by Phil Ford on topic Scratch Building a Mercury Marlin
Hull planking looking rather neat. Where does the mast go?
7 years 5 months ago #16033 by Brian
Phil, I can't tell you as there may be those of tender years reading this .
7 years 5 months ago #16039 by Brian
Control line circle? Boating lake? Mercury Marlin the model that has it all.
Viking theme by kind permission of Knudssen Thorssen Larssen.
