Phil's Phase 6 Build
16 Nov 2018 16:06 #18294 by Dave Rogers
Replied by Dave Rogers on topic Phil's Phase 6 Build
Great stuff phil, if only I can get the enthusiasm to tart mine up?
16 Nov 2018 16:13 #18295 by Phil Ford
You could do Dave when you got a few hours to spare as it is only polyester covered (hopefully) because if it is covered in Monocoat you got trouble. It flies well so leave it alone.:lol:
16 Nov 2018 19:42 #18298 by 4Pedalsfly
Replied by 4Pedalsfly on topic Phil's Phase 6 Build
Well done Phil - Look forward to seeing video of the maiden flight - this weekend ?
16 Nov 2018 21:05 #18300 by Phil Ford
Possibly. Likely
  • JacobWinfield12
16 Nov 2018 21:56 #18302 by JacobWinfield12
Replied by JacobWinfield12 on topic Phil's Phase 6 Build
Brilliant work Phil
17 Nov 2018 08:12 #18303 by Brian
Replied by Brian on topic Phil's Phase 6 Build
Hope there's nothing significant about the Phase 6 being in front of the big bin in the last photo.
Hope the maiden goes well.
18 Nov 2018 16:11 #18306 by Phil Ford
Brian wrote: Hope the maiden goes well.
It didn't! Wind was nowhere as forecast. :( Another day maybe in the forthcoming week.
Thanks go to Mike on the servo cover tip. ;)
21 Nov 2018 16:57 - 21 Nov 2018 16:58 #18312 by Phil Ford
Following on from Mike's tips on Saturday I have replaced the control snakes with 1.5mm piano wire. Soldered 2mm adaptors on to the horn ends and Z bends at servo arm. Managed to slide a brace along the snake outers down inside the depths of the fuselage (a job I should've done before gluing on the bottom fuselage floor) to stop any flex.
Also for the future "hoolies" built in a ballast box. ;)
Waiting now for a good wind at a decent slope!
Last edit: 21 Nov 2018 16:58 by Phil Ford.
Time to create page: 0.332 seconds
