3D Printing
5 years 10 months ago #21151 by Phil Ford
Brian wrote: Perhaps I'll be able to find something from Motion RC that appeals, their little EDF Mig 15 flew very well, but only for about half a minute before I completely lost it, however it may still fly again, a little shorter in the nose and more wrinkles than the average tortoise, at least it doesn't need cyano to hold it together.
Welcome back to divided Britain.
Steam it Brian. Ask Simon O about Sabre crinkles. Although Tim Sullings did sort it out for him. Wonderful things kettles and glue.
5 years 9 months ago #21397 by Brian
I started this thread in the hope that I would eventually have a fairly cheap 3d printed model. I have had a few problems with the printer's extruder, finally I bought an upgrade kit for it and fitted the rebuilt extruder with a new "hot end". I thought that upgrading the extruder and upgrading the printer's software would have improved things a bit, I didn't realise just how long it takes to "tune" a printer! Since I started the project I've managed to turn about 4kg of PLA filament into unusable bits of what I thought would be either a P_47N with retracts, or the later project of the Black Wing 160. The project hasn't been a total waste of time and materials though. After a lot of emails to the model designers, I have a t last managed to get some of the printed parts aligned and glued. One "good thing" is that the cyano glue from HobbyKing not only works very well, but I seem to have no bad side effects from using it, and as a bonus you get quite a lot of it for the money.
Until recently, I believed that the problem I was having with the model printing was probably caused by my inexperience and initial failure to take any notice of what was written in the handbook. This week after some dialogue with the team at 3dLabPrint I found that the problems were being caused by the "slicer" program supplied by the printer's maker. To buy a program costs around $US 150, this program is used by the model's designers. I found a freely available one on the Internet which has most of the features of the American one, in fact I think it does about everything only a bit slower. It took a couple of days to get the general idea of how the program worked, and another couple of days tinkering with files and settings.The good thing was that the weather was awful, and the challenge took all my concentration, so what was going on outside didn't matter at all.
The first print took almost twenty hours to complete, and was not successful, the joints weren't straight as the wing sections had warped away from the build plate, and most of the internal detail was missing from the structure of the first wing section. I should have looked at the computer display a bit closer, then I would have seen what was going on, its easy to see when the print is examined in its individual layers.
The downloaded program from the designers is in several formats, the complete model is in G-Code, STL files and "factory" files. STL files are the ones I used. These files are representations of the parts of the model. Each part has to be added to the build plate of the printer then "sliced" to enable the printer to produce the part. Printing parts using the data from STL files enables the printer's settings to be adjusted to give the best results, unfortunately and for some reason the designer's haven't explained, the internal structure is removed when the part is prepared for printing. I was told to forget about STL files and slicing etc. and just use the G-Codes
Feeling a bit frustrated at spending so much time on what seemed to be wasted effort, I tried to print from the G-Codes, unfortunately, all the printer settings are embedded in the codes and editing things like speeds and temperature, material flow and retract distance is not possible.
If anyone would like a copy of my P-47N, and I don't think there's anything in the paperwork that prevents me from giving it away, and you'd like to have a go at it, send me your email address and I'll send you the files. You'll be able to download all the other info you need from the 3dLabPrint website.
5 years 8 months ago #21431 by Brian
Finally I gave in and bought the expensive printer control program, fortunately there is a "get out" option and I can get a refund up to 20 days from the original purchase. I felt a bit uncomfortable using the program as I really didn't want to have to learn another set of disciplines. However, after a fair bit of head scratching and stop-start programming, at long last the printer produced a pretty good print. Suitably encouraged, I went ahead and printed all ten sections of the P-47 wing. Today I started to fit the parts together, there's a small amount of "fettling" to do on the mating surfaces, not a lot, but must be done with some care as the wing skins are only 0.40 mm thick. The first three sections of the right wing went together just as described in the manufacturer's videos. I started to feel a bit relaxed about the whole thing. I should have paid more attention when I loaded the files to the printer. For some reason, one section of the wing was too big by roughly 10%. I haven't a clue how this could have happened. I've deleted the appropriate files and re-written them, the printer is now working away in the dark and , I hope its printing the section to the correct scale. The photos are of the oversized wing section, finish is pretty good, the views of the end sections show just how thin the wing skin is. The thickened section is the end that goes on to the build plate, the extra width helps to prevent the part from warping away from the plate during the print process by giving more surface area to "grip" the build plate.This widened section is formed by adding five layers outside the wing profile.
5 years 8 months ago #21432 by DaveBright
Clever stuff!
5 years 8 months ago #21433 by DaveBright
‘Whistle’ while you work Brian? I’ll pop over at the weekend to collect
5 years 8 months ago - 5 years 8 months ago #21441 by Phil Ford
I have three Phoenix gliders but only one wing joiner/securing plate. The originals were ABS plastic but have since cracked and broken up. That left just one joiner, from the last purchase, the pate has now been made of a nylon sort of a stuff and i think not really up to the job long term. So, scratching my head as how to solve this problem I went on thingys to make and found a 3D printer file for a Phoenix with top flat surface for accessories. But I don't own a printer.
Contacted Brian who immediately downloaded the file and who "said no problem". By the time I had had two dinners he got back to me and said "all done". Went over with the wing set and they fitted very well. 10 times more sturdy than HK's flimsy effort. The Guy who created the file needed the plate to carry a GoPro hence the flat surface with a slight downward tilt.
My thanks to Brian. Forgot to ask on Thursday. WhaddoIoweyou. ;)
Last edit: 5 years 8 months ago by Phil Ford.
