Lupo
23 May 2020 20:51 #22582 by AlanF
Replied by AlanF on topic Lupo
I may have this bass ackwards but, what I want is Rolo with a fully symmetrical, probably foam, wing - with the potential for power assist ( maybe plug in). What do you think Mike? By the way I'm impressed with your film cutting skills :)
23 May 2020 21:20 #22583 by MikeSeale
Replied by MikeSeale on topic Lupo
I need to tidy up the plans before publishing, but there is no reason why you couldn't swap wing construction method and aerofoil sections. Sticking a motor in the nose would be possible. But if you wanted to use a spinner it would require some modifications because the nose is a lot taller than it is wide in that area.
Regarding the film cutting...if you mean the graphics/lettering, I do cheat with a vinyl cutter. Liyu vinyl cutter
23 May 2020 21:42 #22584 by kevinross
Replied by kevinross on topic Lupo
I thought you'd been a but quiet recently - but you were sectretly bashing balsa building ANOTHER model.
23 May 2020 21:57 #22588 by AlanF
With regards to film cutting I use either a rotary cutter or get the misses to do it.The results you get from a vinyl cutter make that investment worth considering. Your choice of fuselage x-sections remind me of ridge racer, aeolus, kipper designs; does a round fuselage really make that much difference? The utility of having flat field and slope options in one airframe might make a compromise on performance worth considering. I'm looking at fixing my Demonstrator wing and the gravity fed foam wing cutter you've used on the Lupo/ Rubin( I think I've got that right) is an option I'm considering - it would then have a wider application for a modified Rolo.
23 May 2020 21:58 #22589 by AlanF
kevinross wrote: I thought you'd been a but quiet recently - but you were sectretly bashing balsa building ANOTHER model.
He's a bugger isn't he?
Time to create page: 0.318 seconds
