Chuck Mustang
27 Feb 2021 09:36 #24286 by Phil Ford
Replied by Phil Ford on topic Chuck Mustang
Simon Osborne wrote: You really need to get out more Phil!
I did Simon, see images where grass is visible.:lol:
  • Brian Jackson
27 Feb 2021 12:01 #24287 by Brian Jackson
Replied by Brian Jackson on topic Chuck Mustang
Looks promising Phil. Not only does a "chuckie" get you outdoors, it excercises the arm you use to lift pints. Vital to keep that in trim for the end of lockdown.
28 Feb 2021 17:12 - 28 Feb 2021 17:12 #24294 by Phil Ford
Today another launching exercise up the school fields with a heavy duty elastic band, goes off well then climbs and stalls into a vertical dive. Back home pondered for a while and decided to stick a 5 gm wheel weight on the nose to alter the CG. Back up the field and Yes! Flies wings level and no steep climb. Real pleased. :) Would 've got some video but a dog turned up so gave anymore flights a miss.
Last edit: 28 Feb 2021 17:12 by Phil Ford.
28 Feb 2021 22:24 #24299 by 4Pedalsfly
Replied by 4Pedalsfly on topic Chuck Mustang
Phil - Well done, still not sorted
my stall out - what sort of glide distance are you getting.
Good judgement to avoid possible K9 interference.
01 Mar 2021 09:00 - 01 Mar 2021 09:03 #24300 by Phil Ford
I would guess about 60 feet of "exercise" (or 120 feet if I walk back to the original start point) with a slight nose up launch into a 3-5 mph head wind with an elastic band (the thick white ones). The grandsons turned up at the fields and "grandad can we have a go? It even survived their "chucks" :lol: So far!
Last edit: 01 Mar 2021 09:03 by Phil Ford.
  • Mike Seale
01 Mar 2021 09:47 #24302 by Mike Seale
Replied by Mike Seale on topic Chuck Mustang
I thought a chuck glider was supposed to circle? A little bit of rudder to keep it yawed, the dihedral to stabilise it and the UP elevator that you have to keep it up.
01 Mar 2021 11:05 #24303 by Phil Ford
I thought a one shilling and sixpence (7 1/2 pence to metrics) Saturday morning pocket money Chuck Glider was to cover as much distance as possible therefore open for fun competition. Although it making a circle to come back so you could catch it would be fun too. I created it for the first statement although the elastic band was an after thought ;)
01 Mar 2021 12:06 - 01 Mar 2021 13:55 #24304 by Phil Ford
More - A bit breezier today so I found that the launch angle now needs to be near zero. Baseball cap video snapshots. Anyway enough of this silliness, what's next?
Last edit: 01 Mar 2021 13:55 by Phil Ford. Reason: Grammar wrong
The following user(s) said Thank You: 4Pedalsfly, Brian Jackson
01 Mar 2021 20:15 - 01 Mar 2021 20:16 #24305 by DaveBright
Replied by DaveBright on topic Chuck Mustang
I think you should make one with 6ft span
Last edit: 01 Mar 2021 20:16 by DaveBright.
02 Mar 2021 09:49 - 02 Mar 2021 09:50 #24306 by Phil Ford
Dave Bright wrote: I think you should make one with 6ft span
:ohmy: 1: If a 6 footer was made solid construction then theoretically it would weigh approx 465 gms and need a bloody big elastic band, 2: You would need a big field for maidening. Make a traditional constructed wing for lightness but probably would not survive long. There is free flight and there is free flight limits. ;) I might make a copy of Colin's glider though a bit bigger, only constraint is my balsa stock.
Last edit: 02 Mar 2021 09:50 by Phil Ford.
Time to create page: 0.363 seconds
