GANGSTER 62 LIGHT BY MICK REEVES
  • FrankRobinson
07 Feb 2015 15:11 #3752 by FrankRobinson
GANGSTER 62 LIGHT BY MICK REEVES was created by FrankRobinson
I wanted to find one of the original Gangsters but couldonly come up with the one Mick is doing now so bought the kit last year to get me back into building and the shape of a proper air frame. The kit is for a I/C engine and is so light will fly quite well on a 40 glow (I used to fly them on Merco 61s or the last one on a OS 60 4 stroke quite well) I had a 10cc petrol in the box so thought that would be good but in the end I decided it would make a good electric every day flyer so out with the bits and work out what could be done.
Having fitted a 1400 watt motor and 5 cell to the WOT-WOT which flies around at half throttle and has good flight times I measured up the fus and found that there was plenty of room for a 1500 watt motor and a 6 cell 6000 mamp battery with a 2200 mamp LI_ION for the radio and use high voltage servos, 4 spectrum standard with plastic gears andA High Tec mini metal gear for the steerable nose wheel. The motor is a 400KV 1500 WATT and a 80 amp ESC this should give me on a 6 cell about 8800 rpm and wattage depending on the prop used depending on ground clearance etc.
The kit is laser cut and good quality balsa and light ply, the hardwear a little light for my t aste so binned and decent metal horns etc used, the wing is nearly finished and very light and has been upgraded as required and Cashmored around the under carriage, the wing is quite ridged when complete for built up wing.
I have started to build the fus first having to build a jig, this is not required but my choice, the instructions are in picture and number form with no drawing but are quite well written and the model can be built from these but I am using it to get back into building aircraft so that I have got all the gear ready for building the big Provost.
I hope this as helped, photos when I learn how to get them on the website but you are welome to come and look, I have used traditional glues not insstant so quite a slow build along with all the hospital visits. B)
  • ronp849
07 Feb 2015 15:36 #3755 by ronp849
Replied by ronp849 on topic GANGSTER 62 LIGHT BY MICK REEVES
Hi Frank
You mentioned building a Provost - will this be the jet or prop version?
Ron
  • FrankRobinson
07 Feb 2015 17:04 #3758 by FrankRobinson
Replied by FrankRobinson on topic GANGSTER 62 LIGHT BY MICK REEVES
Prop as it was the first air craft I flew in when I was 10 years old, Father teaching pilots at Ternhill, putting a 3 cyl radial 4 stoke in it 60cc
08 Feb 2015 08:50 #3763 by DaveBright
Replied by DaveBright on topic GANGSTER 62 LIGHT BY MICK REEVES
FrankRobinson wrote: putting a 3 cyl radial 4 stoke in it 60cc
B)
08 Feb 2015 20:16 #3766 by flyingpete
Replied by flyingpete on topic GANGSTER 62 LIGHT BY MICK REEVES
Ahh this brings back fond memories,the gangster was my first low winger back in the 70's fitted with a merco 61,i crashed it and repaired it so many time it must have doubled in weight ,still flew ok :lol:
08 Feb 2015 22:01 #3767 by MikeSeale
Replied by MikeSeale on topic GANGSTER 62 LIGHT BY MICK REEVES
It sounds very nice and I can't wait to see it fly. Can you let us know the motor you are using in the Wots Wot...and presumably the same motor you'll use for the Gangster?
  • FrankRobinson
09 Feb 2015 13:28 #3768 by FrankRobinson
MikeSeale wrote: It sounds very nice and I can't wait to see it fly. Can you let us know the motor you are using in the Wots Wot...and presumably the same motor you'll use for the Gangster?
Hi Mike The motors are for the Gangster Purple Power Profesional PPPO 5055 _400 £61 and for the WOTS WOT PPPO 4260 _ 500 £52 on a 100 amp ESC but proped down and only draws 50 amp at full throttle, nothing gets warm even when I let Dave Loctite have a go. :unsure:
10 Feb 2015 09:59 - 10 Feb 2015 10:03 #3769 by Phil Ford
Replied by Phil Ford on topic GANGSTER 62 LIGHT BY MICK REEVES
FrankRobinson wrote: nothing gets warm even when I let Dave Loctite have a go. :unsure:
You DID'NT let Dave have a go. Wow! Was there any juice left? Was the pack swollen? :lol: :evil: Had'nt you heard about my old Mustang 600? It was smokin' I had to throw my ice cold coke over it before picking it up.... :silly: Nearly lifted the skin off my fingers.
Sorry Dave! A moment of comic genius. :lol:
Last edit: 10 Feb 2015 10:03 by Phil Ford.
10 Feb 2015 15:19 #3771 by DaveBright
I really am only in this club for the 'banter' just as well really!
  • FrankRobinson
13 Feb 2015 12:32 #3794 by FrankRobinson
Learning to transfer photos As you can see undercarrige Cashmooredhttp://wimbornemac.org/media/kunena/emoticons/w00t.png
Time to create page: 0.344 seconds
