Hinge Line Options
  • chris.m
04 May 2015 18:10 - 04 May 2015 18:13 #4376 by chris.m
Replied by chris.m on topic Hinge Line Options
Resin W waterproof pva works well to, you welcome to come and try pulling them out of my 91" extra.......
pushing 80deg of ele throw and not pulled them out yet :evil:
Also dont need to worrie about "greasing" the pin, just roughen them up and glue them in!! when dry just "crack" the hing and it should free up!
Last edit: 04 May 2015 18:13 by chris.m.
The topic has been locked.
04 May 2015 19:50 - 04 May 2015 19:59 #4380 by Phil Ford
I have had a go using this method on the fin as a test. The holes are 4mm and the pin heads are 5mm. I scored around the hole with a scalpel first. (Jon T) Then twisted by hand (or fingers) a 5.5mm drill bit in just a few millmetres. (Alan F) A quick insertion of a soldering iron round tip (in and out) (Kevin R) and then inserted the 4mm hinge. Perfect :) Pivot pin is just level with hinge line. Film covering looks good. So, only 18 other holes to do..... :whistle:
Thanks to all. I'll be following the Forum intensely for the next few months as I'll be unable to drive. Anyways, you won't miss that lunatic with a foamy MXS and a hangar full of virgin warbirds... :lol:
Last edit: 04 May 2015 19:59 by Phil Ford.
04 May 2015 20:18 #4381 by AlanF
Replied by AlanF on topic Hinge Line Options
Nice one Phil, are you going to glue both surfaces at once or one at a time, epoxy, resin W, or gorilla glue - we're on the edge of our seats we need to know the results :)
Good luck for next week!
04 May 2015 21:11 #4383 by MikeSeale
Replied by MikeSeale on topic Hinge Line Options
chris.m wrote: Resin W waterproof pva works well to
Sometimes you do things the way you do because you've always done it that way. PVA certainly would be a lot easier to work with than epoxy...I'll give it a try on my next build/
05 May 2015 08:31 - 05 May 2015 08:36 #4385 by Phil Ford
AlanF wrote: Nice one Phil, are you going to glue both surfaces at once or one at a time, epoxy, resin W, or gorilla glue - we're on the edge of our seats we need to know the results :)
After a few dry checks I will go for both surfaces using 30 min epoxy. Once the edges are virtually touching, then flex the control surface through 45/50 degrees each way (or the angle of the leading and trailing edges). That should align all the hinges so there is no tension between them. I used this method on the Mustang which had recessed hinges with excellent results. On the latter I used the wife's Dove stuff to lubricate/protect the hinge pin and then cleaned off with a Qtip. :lol: Smells nice too!
I have also done it control surface first, setting hinges to sit 90 degrees to surface, but are they 90 degrees? Using a set square and eyesight? But then they could be 88 or 92 due to the short distance to measure against.
PVA? Now that's a thought, because it only sticks wood but has no hold on plastics, but the only thing I believe it has not got is some degree of flexibility which epoxy has.
This thread has certainly brought up some interesting views and methodology :lol: Is that last word legal?
Last edit: 05 May 2015 08:36 by Phil Ford.
05 May 2015 10:14 #4386 by Chris73
Replied by Chris73 on topic Hinge Line Options
[/quote]
[/quote]
All the epoxy i have used goes off like rock, so i doubt there is much flexibility in epoxy. The hinges on my 50cc Yak54 were glued in using PVA and none have come loose over the last 18 months (Tempting fate i know), you just have to make sure you get plenty in the hole, and like Chris said its real easy to clean up any excess
05 May 2015 11:20 #4387 by Phil Ford
REWIND - In fact I have glued the hinges in the control surface first. Why? Well on dry fitting the pin centres move around when flexing the surface against it's companion, gradually opening up the gap. Not good! Whereas if the hinge centre pin is flush with the edge and glued it cannot move. Will find out if this method is best policy in a few hours when the epoxy has set and go to fit the rudder to the fin... ;)
26 May 2015 15:13 - 26 May 2015 15:31 #4605 by Phil Ford
Classic CAP 232 40cc - 60cc
As you can now guess I am able to sit a table to fiddle with models. Better half fetches and carries. :kiss:
Glueing Hinges! Definitely one surface at a time. Control surface first. To refrain from having to cut slots for the pin hinge heads I counter bored the hole slightly and ironed the film where necessary. Bevels now are virtually touching. :) Minimal gap, less chance of flutter.
Another question - Using HD control horns (Miracles from Probuild) , should I epoxy the horn screw in the surface as well or just thread lock the securing nut? Also is 1/2inch the standard distance between the hinge line and the horn screw?
Last edit: 26 May 2015 15:31 by Phil Ford.
26 May 2015 18:42 #4607 by MikeSeale
PhilF51 wrote: Also is 1/2inch the standard distance between the hinge line and the horn screw?
If the hole in the control horn is 1/2 inch in front of the horn screw, yes. This will make the hole line up with the hinge line for the best linkage geometry.
  • Stuartmck
27 May 2015 08:25 #4610 by Stuartmck
Replied by Stuartmck on topic Hinge Line Options
Bit late joining topic, but, I use epoxy, one surface at a time. Also, a drop of oil or vaseline on the pivot point. Using second surface to ensure alignment. Holes were c'bored if required.
Stuart
