Pepsi Chipmunk Build
9 years 1 month ago - 9 years 1 month ago #9625 by Phil Ford
Wow! You have got that far in the build in the time it has took me to paint the living room with the first sealer coat after being plaster skimmed. :whistle: Taking a break now after cleaning rollers and unpainting myself. ;)
Last edit: 9 years 1 month ago by Phil Ford.
  • Banned
  • Banned
9 years 1 month ago #9626 by flyingpete
Phil
Remind me again what you are using for power?and are we using robart hinges or the kavan flat pin hinge supplied with the kit??
9 years 1 month ago #9629 by Phil Ford
Power will be a DLE35RA.
With regards to hinges my Pennzoil has Kavan flat hinges. I had thought about Robart type because you can get the control surfaces closer to the stab, wing, rudder. My concern was there may not be enough wood for Robarts allowing for the slight counter-bored holes. I don't mind Pete, if Robarts are good to go then use them. You have the experience so I'll leave it you.
  • Banned
  • Banned
9 years 1 month ago - 9 years 1 month ago #9640 by flyingpete
Wings sheeted,flaps and ailerons marked out ready to be cut away
Last edit: 9 years 1 month ago by flyingpete.
  • Banned
  • Banned
9 years 4 weeks ago #9644 by flyingpete
Simple construction for the tailplane and elevators built flat on the plan.Once dried the tailplane will be cleaned up and tips sanded to shape and then sheeted with 1/16 balsa.Same with elevator but not sheeted ,also wire ele joiner and supports will be added.Fin and rudder is same constructon
  • Banned
  • Banned
9 years 4 weeks ago #9646 by flyingpete
Fin and rudder built,as with the tailplane the fin is sheeted with1/16 balsa and not the rudder.
Well that's the airframe constructed B)
It's getting to hot in the workshop so I'm having the afternoon off with a couple of ice cold beers.
Time to create page: 0.332 seconds
