Rebuild Thread - EF 104 Extra
27 Feb 2016 19:21 #8130 by flyingpete
Replied by flyingpete on topic Rebuild Thread - EF 104 Extra
Top job B) it's always a nice feeling after you bent it, to see it coming back to life for more punishment.
05 Mar 2016 10:28 #8193 by AlanF
Replied by AlanF on topic Rebuild Thread - EF 104 Extra
Nice work Jon. Do you think that drawing up new formers in CAD and getting parts CNC cut would have been a reasonable alternative to hand cutting? We must have some CAD experts in the club.
What's your plan for the wing repairs? I'm guessing that the wing tube damage extends to all the associated internal ribs.
  • JonTappin
05 Mar 2016 12:25 #8196 by JonTappin
Replied by JonTappin on topic Rebuild Thread - EF 104 Extra
CNC cut parts would have been great Alan, just don't know anyone who could do it, or how much work it would be.
I will update on the wing as I am planning on starting on it today!
  • JonTappin
07 Mar 2016 17:19 - 07 Mar 2016 17:20 #8218 by JonTappin
So, progress over the weekend.
One wing is badly damaged with the wing tube broken out, wing skins are damaged in some places.
First job is to remove the covering, I intended to try to get away with one side only, I chose the top as it will then be all nice and shiny when finished.
First a cut with a sharp blade along the aileron hinge line, then using a covering iron to heat the adhesive, the film is removed.
Last edit: 07 Mar 2016 17:20 by JonTappin.
  • JonTappin
07 Mar 2016 17:22 #8219 by JonTappin
Some damage is obvious at the tip and root, root rib pretty broken!
  • JonTappin
07 Mar 2016 17:40 - 07 Mar 2016 17:42 #8220 by JonTappin
I then carefully removed the balsa skins full length to reveal the whole structure as I want to be sure I have found and repaired all of the damage as there may be broken joints that would not be obvious without doing this, when doing this I was careful not to damage any of the structure which seemed intact..
Once removed, all of the damage is revealed, both the root and second ribs are basically destroyed, but further out the structure is pretty much unaffected, considering the carbon wing tube snapped in the crash, this says something about the strength of the wing structure!
In the photos I have inserted the carbon wing tube to straighten out the glass liner tube which was bent and is fractured, but all of the pieces are there. I just need to decide how I repair this while keeping it's shape and not gluing the wing tube in permanently! I have some ideas but haven't yet decided on the best one.
Last edit: 07 Mar 2016 17:42 by JonTappin.
  • JonTappin
07 Mar 2016 17:46 - 07 Mar 2016 17:51 #8221 by JonTappin
Most of the damaged structure is now removed in these photos, I also removed the vertical ply web still in place in these images.
Now the internals were revealed it was clear that to do a proper job I would also need to remove the covering from the bottom as well, as there are a few areas of damage to the bottom sheet, I think I should be able to patch these without having to remove all of this sheeting though.
Last edit: 07 Mar 2016 17:51 by JonTappin.
  • JonTappin
07 Mar 2016 17:48 - 07 Mar 2016 17:48 #8222 by JonTappin
Final bit completed was making a start on making new parts, using the original bits tacked back together to create a pattern, just as I did with the motor box.
To be continued!! :)
Last edit: 07 Mar 2016 17:48 by JonTappin.
07 Mar 2016 18:37 #8223 by Chris73
Replied by Chris73 on topic Rebuild Thread - EF 104 Extra
Looks like your making good progress, keep the photos coming will be interesting to see how you repair everything
07 Mar 2016 19:56 #8225 by flyingpete
Nice work Jon! Nice to see you are not frightened of a bit of major surgery on a model, as many would have binned it :woohoo:
Time to create page: 0.400 seconds
