Spectrum DX6 Fault
  • FlyBuster18
29 Jul 2018 13:48 #17271 by FlyBuster18
Spectrum DX6 Fault was created by FlyBuster18
Hi Guy's Please can a club knowledgable member help me sort out my Spectrum DX6 radio as it will not work as a wired controller to the club slave TX, although it has always been ok in the past. Also when I tried to run my iMac simulator it will not work. When John Ireland switched it to Wireless mode it did work to a different club radio, but the controls seemed fierce to me.
I have the full handbook. Perhaps I should re-bind the TX to the RX !! any thoughts anyone?
29 Jul 2018 16:39 #17272 by MikeSeale
Replied by MikeSeale on topic Spectrum DX6 Fault
Can't help other than to suggest that the master transmitter must be switched on and the slave switched off BEFORE the wire is used.
Same with the simulator...DX6 switched off BEFORE using the wire.
  • FlyBuster18
29 Jul 2018 22:47 #17275 by FlyBuster18
Replied by FlyBuster18 on topic Spectrum DX6 Fault
Thank you Mike. I have tried the Simulator all ways to no avail. I will try the plane tomorrow.
29 Jul 2018 23:20 #17276 by MikeSeale
One more thought...is the wired output disabled when the DX6 is set to wireless trainer? IOW have you reset the trainer option to wired?
30 Jul 2018 09:38 #17277 by 4Pedalsfly
Replied by 4Pedalsfly on topic Spectrum DX6 Fault
I am slightly confused - The DX6e wireless transmitters that we now use for training DO NOT have a socket
to accept a trainer lead, all training is via the wireless connection.
Can Ernie pls confirm what transmitter he is using.
Thanks
  • FlyBuster18
30 Jul 2018 11:10 #17278 by FlyBuster18
Hi I am using a DX6 which has a trainer socket. When used with the club DX6e without the cable for wireless operation it worked ok.
31 Jul 2018 00:14 #17284 by 4Pedalsfly
FlyBuster18 wrote: Hi I am using a DX6 which has a trainer socket. When used with the club DX6e without the cable for wireless operation it worked ok.
Hi Ernie - When you buddied with the Club's DX6e you would have bound your transmitter to the receiver inside the Club's Master DX6e transmitter.
Pls excuse me for asking but have you rebound your transmitter to your model ?
31 Jul 2018 09:28 - 31 Jul 2018 09:28 #17285 by JRI
Replied by JRI on topic Spectrum DX6 Fault
Your transmitter is broken Ernie - if you want to use the wired connection again then you must get it fixed. You cannot use the wired connection if you know it is faulty or temperamental because you risk losing your model and are breaking the law by ignoring CPA 658: 4.2.1 Article 138 – Endangering safety of any person or property ‘A person must not recklessly or negligently cause or permit an aircraft to endanger any person or property.’
Last edit: 31 Jul 2018 09:28 by JRI.
31 Jul 2018 09:49 #17286 by 4Pedalsfly
Ernie - Worth contacting - Model Radio Workshop in Southampton.
Contact - Mike Ridley - tel 07708 436163
www.modelradioworkshop.co.uk
If you make an appointment, Mike will look at it whilst you wait.
  • FlyBuster18
05 Aug 2018 16:04 #17311 by FlyBuster18
No Colin I have not Re-bound my TX. But surprise my TX works ok direct to my model. To check that it works to the club slave I will have to make a visit to Cashmoor.
Thank you
Ernie
Time to create page: 0.421 seconds
