Carbon pushrods
10 years 9 months ago #3372 by MikeSeale
Replied by MikeSeale on topic Carbon pushrods
Stuartmck wrote: There are special receivers for use in composite fuselages. I believe a carbon rod, with suitable guides, would be better than an inner and an outer. Again, I have seen a lot of models with carbon rods and std Rx's, but not known of any problems. Now, when shall I start repairing that xxxxxxx!
Stuart
The special receivers have longer antennae so that they can be placed outside a carbon fuselage. Other composites (glass and kevlar) do not need the antennae outside because they do not shield the signal like carbon does. A carbon-friendly receiver will not be necessary in a wooden hurricane even if it does have a few lengths of carbon in it.
10 years 9 months ago #3373 by 4Pedalsfly
Replied by 4Pedalsfly on topic Carbon pushrods
Pete - Have you considered using a closed loop system on both rudder & the
elevator, would be very light.
Would require a short pushrod connected to bellcrank at the rear to work the
elevator.
Colin A.
  • Banned
  • Banned
10 years 9 months ago #3375 by flyingpete
Replied by flyingpete on topic Carbon pushrods
Thank's guy's some good advice B) another route i am looking at is a pair of JR very high torque smaller servos running on 7.4 volt.
10 years 9 months ago #3385 by kevinross
Replied by kevinross on topic Carbon pushrods
Pete - just seen your post re carbon in carbon pushrods
Support Mike Seals comments - I once installed a carbon push rod in short carbon support bushes and they fretted very badly with the dust residue causing friction so Don't do it !
Time to create page: 0.222 seconds
