JR Powersafe Receiver
25 Oct 2015 20:28 #6715 by Chris73
JR Powersafe Receiver was created by Chris73
After today's flying session I charged my receiver batteries, one pack took almost 2000mah and the other pack was still fully charged, normally they are within a 100mah of each other as the receiver is supposed to pull equally from both packs
Set up is JR powersafe receiver and two 2 cell 5000mah lipo's , any ideas why this would be???
  • Adrian
26 Oct 2015 14:53 - 26 Oct 2015 15:02 #6729 by Adrian
Replied by Adrian on topic JR Powersafe Receiver
if you unplug the battery that was being discharged does the rx still work?
what if you swap the batteries in the rx and leave it on, wiggle it for 30mins (or servo test mode on TX) does the same pack become discharged?
if you have a ammeter you could measure the current being pulled. It is looking probable that there is an issue with the rx.
Ade
Last edit: 26 Oct 2015 15:02 by Adrian.
28 Oct 2015 13:22 #6747 by JonTappin
Replied by JonTappin on topic JR Powersafe Receiver
+1 What Ade said.
Sounds likely that you have a receiver fault, you will only know by testing each input as suggested. Stupid question, but is there any chance the pack that didn't discharge wasn't properly connected?
The following user(s) said Thank You: Chris73, Adrian
28 Oct 2015 16:37 #6748 by Chris73
Replied by Chris73 on topic JR Powersafe Receiver
Pretty sure the pack was connected as this is the second time it has done it, I am using a deans to EC5 adaptor. As most of you know my soldering is not the best, but Mike has kindly agreed to give me a soldering lesson, so I will change all of the connectors so I can eliminate the adaptor. Then I will try what has been suggested and see how it goes, hopefully it is just the adaptor that has failed because the receiver wasn't exactly cheap :(
  • Adrian
28 Oct 2015 17:07 - 28 Oct 2015 17:07 #6749 by Adrian
its kinda a process of elimination, plugging one pack in to each port and seeing if it works, then plug the other pack in to each port swapping adapter cables.
by using each combination you can then work out exactly which component is buggered.
then bin that component and never have it darken a model ever again :-)
Last edit: 28 Oct 2015 17:07 by Adrian.
28 Oct 2015 17:10 #6750 by JonTappin
Chris73 wrote: the receiver wasn't exactly cheap :(
How old is it Chris, MacGregor should cover it under warranty if it is faulty.
28 Oct 2015 17:48 #6751 by Chris73
It's under a year old, don't think I will have the receipt anymore though
Anyway, first job is to change the connectors and then methodically work through it all so I know which bit has failed
28 Oct 2015 19:14 #6753 by JonTappin
Chris73 wrote: It's under a year old, don't think I will have the receipt anymore though
If you do find that its faulty, let me know, I can probably help you with that.
29 Oct 2015 16:29 #6755 by Chris73
Ok, think I may have solved it, whilst testing the voltage of each pack I found that if I wiggled the live wire just in the right place on one the packs I could get the voltage to drop from 8.2v to 4.3v. So that pack is now being thrown away and I have a new pack. Still going to change the connectors so I can get rid of the adaptor as this is just another failure point, fingers crossed this will solve the problem.
Will have a couple of flights at the weekend and then check the packs just to make sure
29 Oct 2015 17:12 #6756 by JonTappin
I'd be surprised if that isn't your problem Chris, as soon as the voltage drops the rx will take power from the other pack, under vibration it is probably happening constantly.
Do as you suggest though and check after a couple of flights.
Time to create page: 0.357 seconds
