Service/repair to O.S. 120 four stroke?
8 years 9 months ago #11400 by
I have acquired an almost new OS 120. Tried to start it but fuel leaking from pumped carburettor. Does anyone know where I can get it checked out/ repaired?
8 years 9 months ago #11401 by 4Pedalsfly
Replied by 4Pedalsfly on topic Service/repair to O.S. 120 four stroke?
Simon - I had a similar problem with the same motor about 10 years ago
& finished up sending it back to Ripmax who fixed it for me.
I cannot recall what they charged but I do not know who else services O.S engines.
What does the seller have to say ?
Hope you get it sorted.
8 years 9 months ago #11403 by
Colin, I bought it some months ago and now needing the model finished off the build and tried to fire it up. Don't think the seller will be too interested now. I will take your advice ano get in touch with Ripmax.
8 years 9 months ago - 8 years 9 months ago #11404 by Phil Ford
Replied by Phil Ford on topic Service/repair to O.S. 120 four stroke?
May I suggest "Just Engines" they are based at Shaftesbury and very knowledgeable plus repair and carry spares for OS, ASP and NGH and others. Give them a ring to either sort it for you or supply parts for the job.
www.justengines.co.uk/
Last edit: 8 years 9 months ago by Phil Ford.
8 years 9 months ago #11407 by
Many thanks Phil
8 years 9 months ago - 8 years 9 months ago #11409 by JonTappin
Replied by JonTappin on topic Service/repair to O.S. 120 four stroke?
Don't send it off yet Simon, it is a pumped engine so will drip fuel if not running as the pump will be constantly delivering fuel when ever it is turning over.
You might just need some help getting it running initially before assuming there is a problem with it. Can you bring it to Cashmoor so we can have a try there?
Last edit: 8 years 9 months ago by JonTappin.
Time to create page: 0.240 seconds
