Covering
30 Apr 2017 21:13 #12696 by Chris73
Covering was created by Chris73
Need some advice please, the covering came off the bottom of my Extra the other week. I have tried to iron it back but the area is where the exhausts exit and there is lots of oil on the wood, and the covering does not want to stick anymore.
How can I prep the wood so the covering will stick properly??
Thanks
Chris
30 Apr 2017 22:17 - 30 Apr 2017 22:19 #12697 by JonTappin
Replied by JonTappin on topic Covering
Get some kitchen towel, single thickness, put it onto the oil soaked wood then press a hot covering iron onto it and it will draw the oil out into the paper, keep repeating, changing the kitchen towel each time so you always use a clean piece until you can't get any more oil out.
Then seal the surface of the wood with something, Balsaloc, epoxy or even thin cyano rubbed into it. Lightly rub it down to take the high spots off and then recover.
You might need to patch with a new piece of film as it may have traces of oil on the surface.
Last edit: 30 Apr 2017 22:19 by JonTappin.
30 Apr 2017 22:28 #12698 by 4Pedalsfly
Replied by 4Pedalsfly on topic Covering
Hi Chris - Not aware of any method to remove the soaked in oil.
Couple of suggestions :
1 - Try sticking it over the oily bit with cyno, then shrinking​ with iron.
2 - Cut out the oily wood & replace with a new bit, sand till surface blends in.
Hope this helps
30 Apr 2017 22:34 #12699 by Brian
Replied by Brian on topic Covering
I had the same problem with the covering lifting from an oil soaked surface. Using kitchen roll and a hot iron gets most of the oil out, then cover the affected area with either talcum powder or cornflour. Leave it as long as you can, then apply kitchen roll and a hot iron over the talc/cornflour. A good and effective seal is ordinary knotting varnish, thinned with methylated spirit. Don't just brush it on, scrub it into the surface of the wood. Brush on Balsaloc or Coverite, iron on your choice of covering, and the model will be as good as new.
30 Apr 2017 23:06 - 30 Apr 2017 23:11 #12700 by Chris73
Replied by Chris73 on topic Covering
Thanks for you help, I will remove the covering and see how bad the wood is, if not too bad I will try the paper towel and iron, if really bad I will cut it out and glue in a new piece of wood
I will replace all the covering on the bottom as it is one piece so probably easier than trying to patch it
Last edit: 30 Apr 2017 23:11 by Chris73.
30 Apr 2017 23:50 #12702 by MikeSeale
Replied by MikeSeale on topic Covering
Use a cigarette lighter to get the oil to ignition point. After the fire dies down replace with a model designed for electric power.
01 May 2017 11:08 #12704 by DavidTappin
Replied by DavidTappin on topic Covering
Mike suggested
Shame on you Mike, call yourself a dedicated electrophile, fancy proposing the use of petrol to start the fire.
Shouldn't you just attach a well charged LiPo cell to the oily area and then touch the +ve and -ve wires together to achieve the desired result?
01 May 2017 11:11 #12705 by Phil Ford
Replied by Phil Ford on topic Covering
MikeSeale wrote: Use a cigarette lighter to get the oil to ignition point. After the fire dies down replace with a model designed for electric power.
:lol: :blink:
01 May 2017 20:43 #12706 by 4Pedalsfly
Chris - A bit more info for you.
Deluxe Materials sell a product called "COVER GRIP " it's a liquid which when dry is activated with
a warm iron & they claim it will allow covering materials to adhere to oil affected areas.
Worth a go & a lot cheaper than a recover job.
Website deluxe materials.com
01 May 2017 21:22 #12707 by JRI
Replied by JRI on topic Covering
Use bicarbonate of soda (the cooking stuff), it soaks up oil and you simply scrape it of when it goes cakey and put on another layer. Totally worked for my old oil soaked glow models and should work for petrol residues too...
