Covering
03 May 2017 09:25 #12733 by Chris73
Replied by Chris73 on topic Covering
Needless to say, but I didnt go with Mike's suggestion
I used a hot iron and paper towel, then lightly sanded the area and sealed with thinned epoxy, seems to have worked ok
03 May 2017 09:35 - 03 May 2017 09:42 #12735 by AlanF
Replied by AlanF on topic Covering
Nicely done Chris.
Did you seal down the edges of the film after covering, if so what did you use? I've used a Solar Film product called Clearcoat on my glow models in the past which has worked ok but haven't used anything on the Gas models.
Edit:
That's not true I've used it on my little Extra - it works ok !
Last edit: 03 May 2017 09:42 by AlanF.
03 May 2017 09:56 #12736 by Chris73
I used a pen that is designed for sealing the edges of graphics, I only sealed the front edge of the point as that will be in the airflow
03 May 2017 10:04 #12737 by Phil Ford
Replied by Phil Ford on topic Covering
Chris73 wrote: Needless to say, but I did'nt go with Mike's suggestion
Good job too! Would've started a forest fire.:silly:
03 May 2017 12:50 #12747 by JonTappin
Replied by JonTappin on topic Covering
AlanF wrote: Nicely done Chris.
Edit:
I use one of these, lasts for ages and easy to apply
www.signmakingandsupplies.co.uk/seal-it-pen-17298-p.asp
Time to create page: 0.281 seconds
