Ultra Flash Fibreglass repair
  • JonTappin
6 years 11 months ago #18202 by JonTappin
Replied by JonTappin on topic Ultra Flash Fibreglass repair
kevinross wrote: Ouch !
The repair looks fairly light I understand there was some Pb in the nose. Just wondered if these aircraft are c of g sensitive and would you plan to rebalance the model statically before flight or "suck it and see"
I will recheck the cg before flight, but don't expect it to be very different, most of the filler will be rubbed off before painting, so it won't add much weight.
I will put the original lead back in. I wanted to try moving the cg forward a little anyway, so the added weight will help with that.
6 years 11 months ago #18205 by 4Pedalsfly
Replied by 4Pedalsfly on topic Ultra Flash Fibreglass repair
Jon - Sorry to read of your incident, the nose acting as a crumple zone no doubt prevented
more serious damage.
I like the cleaver way you have repaired the nose, sadly the bank will claim other models.
  • JonTappin
6 years 11 months ago #18209 by JonTappin
Thanks Colin, I'm afraid you're right, I don't think I'll be the last victim unfortunately
  • JonTappin
6 years 11 months ago #18260 by JonTappin
Slow progress over the past couple of weeks due to DIY :( but back on it and things starting to look a lot better.
After lots of filling/rubbing down/filling repeats, it was starting to look better, I used a sanding block and wet and dry to rub down as this will take the high spots off. When you get to the point that it seems quite good, a useful tip is to give it a coat of primer, or in this case primer filler, then rub down again, the filler being a different colour will reveal any existing low spots
  • JonTappin
6 years 11 months ago #18261 by JonTappin
While i was at it I also repaired the noseleg opening as it was slightly damaged by the previous owner, I am planning to put doors on it so this needed doing, bit of glass and epoxy followed by filler sorted this.
  • JonTappin
6 years 11 months ago #18262 by JonTappin
Although only one wingtip was damaged it the accident, the other had been badly scuffed underneath before I got it, so I have repaired both
