Any Ideas? Novice builder /flyer
  • Simonosborne53
24 Sep 2016 15:29 #10028 by Simonosborne53
Any Ideas? Novice builder /flyer was created by Simonosborne53
I have completed building up my Wot4 a with Quantum 11 - 40 motor, suitable speed controller and Futaba 8j radio. Everything is fine and finished except propulsion. The speed controller requires a set up procedure on a various beep sequence when the battery is connected, moving throttle from full to minimum. Once I have gone through the sequence finishing at no throttle, the distress sound from the controller that preceded the set up sequence stops. However when I open the throttle again the distress sounds start again and the motor does not spin. Any ideas?
Suggestions gratefully received
Simon
24 Sep 2016 17:36 - 24 Sep 2016 17:47 #10031 by Phil Ford
Replied by Phil Ford on topic Any Ideas? Novice builder /flyer
Hi Simon, the series of beeps are to program certain parameters, brake on/off, number of cells LiPo , timing, etc etc. You don't say what make of ESC but generally they all follow the same menu for setting up. Most except for really cheap and nasty ones will automatically set themselves with default values. You can then make changes depending on the model requirements to suit yourself. But anyway let's keep it simple!
You say "distress". Have not heard that one before!
I am assuming that you are connecting power (I would recommend not having the prop on just yet for safety) and you should get one beep or a silly tune (arming) then a series of beeps (number of cells in LiPo pack, then one long beep or silly tune. Ready to fly Check direction of rotation of motor by using a little throttle. Anti-clockwise as you look at it from the front. If going in wrong direction then swap any two motor connections.
Now if I am assuming right, at the end of the arming sequence your getting a beep, beep, beep? This is the ESC not knowing where the low throttle is or throttle lead not plugged in correctly. Disconnect power pack. Make sure your throttle stick is in the low position and also check the throttle trim is middle or low. Reconnect power. Try again. Don't move the throttle stick or you will enter ESC menu.
Still getting beep beep beep? Check your throttle direction in the Futaba TX menu. It will be under servo direction menu. Change it. It may be reversed and the ESC safety feature is doing it's job. Don't want to plug in power pack and motor goes full power and the consequences of that are.......... :whistle:
See how that goes Simon.
You are connecting power with the throttle low?
Last edit: 24 Sep 2016 17:47 by Phil Ford.
The following user(s) said Thank You: Simonosborne53
24 Sep 2016 18:18 #10033 by MikeSeale
Replied by MikeSeale on topic Any Ideas? Novice builder /flyer
Tell us what speed controller you are using. All you say is that it has a suitable speed controller, but I'm not familiar with this brand!!!
24 Sep 2016 18:25 #10034 by MikeSeale
I've just realised...you're using futaba. You MUST reverse the throttle channel on your transmitter because futaba in their infinite wisdom have decided that low throttle is 2ms and high throttle is 1ms. This is the opposite to all other radio manufacturers. You can, of course, check that this is needed by connecting the battery to the ESC with the throttle fully OPEN. Your ESC will think the throttle is closed and you will get the normal sequence of beeps followed by silence. The distress you are hearing is because your ESC thinks you are at full throttle when you have the stick back.
Once you have reversed the throttle you might need to go back through the programming sequence if you accidentally messed something up when you tried it with a reversed throttle.
Make sure you do all of the above with your propeller removed, just in case the motor kicks into life at full throttle.
24 Sep 2016 18:29 #10035 by Chris73
Replied by Chris73 on topic Any Ideas? Novice builder /flyer
When you have it working dont forget to check your failsafe is working, once again I would do this with the prop removed
  • Simonosborne53
24 Sep 2016 18:42 #10036 by Simonosborne53
Replied by Simonosborne53 on topic Any Ideas? Novice builder /flyer
Mike its DYNAMIC. Can't find anything about them on the internet though, I got it from Inwood models. They did not have the Ripmax as specified in the Wot4 instructions so supplied their equivalent
  • Simonosborne53
24 Sep 2016 19:32 #10037 by Simonosborne53
Mike I've checked the transmitter display for servos and it's showing throttle is already reversed. I will try the set up sequence again. If all else fails I will take the kit to Cashmoor with me!
26 Sep 2016 09:54 #10057 by 4Pedalsfly
Replied by 4Pedalsfly on topic Any Ideas? Novice builder /flyer
Simon - If you cannot program it listening to the music ( it does get very confusing ) you can purchase
a Programming Card - you simply plug it in to the ESC , set the parameters you want on the card, press o.k & it's done.
Inwood should be able to supply this for the "Dynamic" ESC.
If I may stress again do all this WITH THE PROP OFF.
Hope this helps.
Colin.A
  • Simonosborne53
26 Sep 2016 19:15 #10061 by Simonosborne53
Thanks Colin and everyone who contributed ideas, it appears the speed controller has a fault. Inwood model supplies who sold it to me along with other kit have sent a new one today after I explained everything they suggested had been tried to no avail. I'm very impressed by their service and prices by the way. Fingers crossed the replacement works!
