The Wing Returns
29 Jun 2017 13:18 - 29 Jun 2017 19:06 #13159 by Phil Ford
The Wing Returns was created by Phil Ford
I really miss the X fighter (aka Flying Dildo) so thought it time to make a new one, sort of. Based on the JP Si wing I am going to cut out some lite ply for the fuselage and formers. The question is - what sort of pusher motor angle in degrees? I was thinking 3 degrees up from wing centre line. Side thrust angle nil?
Image 2: Flew beautifully but just kept going n going n going and disappeared. :lol: August 2014
Last edit: 29 Jun 2017 19:06 by Phil Ford.
29 Jun 2017 17:20 #13162 by Brian
Replied by Brian on topic The Wing Returns
Hi Phil, if your drawing is the right way up, the motor has upthrust. It should be angled three degrees the other way, with no side thrust. The set-up works OK on my Raven flying wing..
29 Jun 2017 19:02 #13163 by Phil Ford
Replied by Phil Ford on topic The Wing Returns
Thanks Brian. In my earlier versions of powered wings I think i had the motor angled the same as the slope of the wing.
The reason I thought it may need upthrust is my high wing UAV is a pusher which has 2 deg upthrust which is not enough, makers error, and therefore I have ordered a 3D printed version motor mount which gives 6 deg up and 2 deg side which will hopefully stop nose down on applying throttle as many users have reported.
29 Jun 2017 19:51 #13164 by Dave Rogers
Replied by Dave Rogers on topic The Wing Returns
Great news! It means we can use phrases again up the field like
" oh no Phil has got his dildo out again"
30 Jun 2017 18:23 #13168 by Phil Ford
Dave Rogers wrote: Great news! It means we can use phrases again up the field like
Not necessarily Dave, it may not look like previous incarnations.
