Observer UAV Mods
09 Jul 2017 12:37 #13246 by Phil Ford
Observer UAV Mods was created by Phil Ford
A bit of a story but bear with me! My Observer camera ship had a strange characteristic of diving or nosing down when using a lot of throttle, therefore taking off was done gently at take-off but God help you if you were not ready and you opened up for WOT in flight. Although t it does fly easily at 1/3rd throttle. Anyway, after a lot of searching found that many other owners had the same issue. Someone discovered that the motor thrust angle is 2 deg and should be ideally at 6 deg with 2 deg of left (because it is a pusher). He also posted a link to a place in Belguim where they have created a modified motor mount using a 3D printer. Great so ordered one, looking forward in a weeks time for the said mod to arrive.
It did! But WTF is this? Image one is what I should have got. Image two what I actually have. I don't think it will fit.:lol: Got to laugh because I might just scream instead. Obviously a cock up (hopefully).
09 Jul 2017 13:53 - 09 Jul 2017 13:55 #13247 by Phil Ford
Replied by Phil Ford on topic Observer UAV Mods
After doing a fair bit of reverse searching through my browser history I found the page that demonstrated two versions of the motor mount, one for 11 inch & 12 inch props with either CW or CCW drive train. The latter item for side thrust angle improvement.
I also discovered the designers page and managed to download the 3D printer files. Below is what I want to achieve and a 3D snapshot of the item in question. If I don't get a response from Belgium then I will have to find someone with a 3D printer.;)
Oh, apparently the mount should be 9 degrees not 6 deg downthrust
Last edit: 09 Jul 2017 13:55 by Phil Ford.
09 Jul 2017 18:05 #13251 by 4Pedalsfly
Replied by 4Pedalsfly on topic Observer UAV Mods
Phil - I know a local model helicopter guy who is well into 3D printing bits for his helicopters.
Let me know if you wish to go that route.
09 Jul 2017 18:29 #13254 by kevinross
Replied by kevinross on topic Observer UAV Mods
ronp849 bought Franks 3D printer but don't know what capability he has reached.
09 Jul 2017 19:28 #13257 by DavidTappin
Replied by DavidTappin on topic Observer UAV Mods
Phil mentioned that he had a
bear with me
If it comes with you again I should leave your honey sandwiches at home Phil, they can get a bit possessive also you know what they do in the woods and we don't want any of that behaviour.
  • ronp849
09 Jul 2017 20:06 - 09 Jul 2017 20:08 #13258 by ronp849
Replied by ronp849 on topic Observer UAV Mods
Hi Phil
I have downloaded the attached file - is this the one you want?
In the meantime I will have a go at printing it.
Can you forward the file you have - is it an STL file?
Last edit: 09 Jul 2017 20:08 by ronp849.
10 Jul 2017 10:05 - 10 Jul 2017 10:07 #13261 by Phil Ford
Wow! That's the little devil.:woohoo: 9 deg and 2 deg. Many thanks.
Yes Ron, I do have STL files but not sure which one is the master printer file. I have attached the ZIp file that I have. Note there maybe different files depending on motor rotation direction. Mine is CW.
Last edit: 10 Jul 2017 10:07 by Phil Ford.
13 Jul 2017 11:11 - 13 Jul 2017 11:12 #13278 by Phil Ford
After sending the files to Ron, thought no more about until Ron turned up at Cashmoor yesterday with this little object. Created on the late Frank Robinson's 3D printer. I believe the nozzle size was 0.5 mm. A finer surface would need a smaller nozzle but increases printing time and costs. Assuming the printer is able to make finer objects. Will have to fit the part and see how it goes.
Last edit: 13 Jul 2017 11:12 by Phil Ford.
14 Jul 2017 10:59 #13286 by Phil Ford
The part needed some smoothing down with fine sandpaper where it slots into the motor pod. Now fitted as seen in image.
Time to create page: 0.440 seconds
