Can LiPo Current Interfere with Radio ?
  • 4Pedalsfly
01 Feb 2018 10:10 #15590 by 4Pedalsfly
Can LiPo Current Interfere with Radio ? was created by 4Pedalsfly
Hi Guys - Hope you can settle my mind on this - see pic attached.
In my latest project I finish up with the 2.4 GHz aerial wire about 6mm from the LiPo cable.
Is there any danger that current flowing from the battery will interfere with the radio ?
Thanks
01 Feb 2018 11:30 #15593 by MikeSeale
Replied by MikeSeale on topic Can LiPo Current Interfere with Radio ?
No
  • 4Pedalsfly
01 Feb 2018 20:31 #15610 by 4Pedalsfly
Replied by 4Pedalsfly on topic Can LiPo Current Interfere with Radio ?
MikeSeale wrote: No
Thanks Mike - That's the answer I was hoping for, I'm assuming the explanation is a bit complicated.
01 Feb 2018 20:38 #15611 by MikeSeale
4Pedalsfly wrote:
MikeSeale wrote: No
You didn't say you wanted an explanation...here goes...
No, current from a battery cannot interfere with the signal to a 2.4GHz receiver.
01 Feb 2018 20:41 #15612 by MikeSeale
But don't forget that thick wires and a solid lump of battery can create a shadow that prevents your signal reaching the receiver...not the same as the question you asked though.
  • 4Pedalsfly
02 Feb 2018 09:30 #15614 by 4Pedalsfly
MikeSeale wrote: But don't forget that thick wires and a solid lump of battery can create a shadow that prevents your signal reaching the receiver...not the same as the question you asked though.
Mike - Thanks again, I'm using FrSky rx with twin aerials, one goes inside the wing & the other down the fuselage away
from the battery so hopefully will not be effected by the "shadow" effect.
Time to create page: 0.617 seconds
