How do I slow them down?
  • Simon O
23 Jan 2019 17:59 #18781 by Simon O
How do I slow them down? was created by Simon O
I have installed servo driven retracts in a ARTF model. I use Futaba radio gear with savox digital sc-025mg servos. Question is how do I go about slowing down the 2 servos that extend and retract the landing gear?
Many thanks
Simon
23 Jan 2019 18:14 - 23 Jan 2019 18:15 #18782 by Phil Ford
Replied by Phil Ford on topic How do I slow them down?
Not sure about Futaba as I am a JR/OpenTX man, but look in main set-up menu for motor speed then select channel to change
Last edit: 23 Jan 2019 18:15 by Phil Ford.
23 Jan 2019 18:55 #18783 by DaveBright
Replied by DaveBright on topic How do I slow them down?
Hi Simon, as Phil said, some sets allow a servo slow function in the programming menu - not sure if your Futaba does this?
Failing that : www.logicrc.com/?ItemId=P-FS-SS&s=c:0,c:50,c:50-60,b:Fusion
  • Simon O
23 Jan 2019 19:41 #18784 by Simon O
Replied by Simon O on topic How do I slow them down?
Thanks for that Dave. Something to look into
23 Jan 2019 22:43 #18786 by kevinross
Replied by kevinross on topic How do I slow them down?
If your Futaba gear does not have a "servo speed" function in the program menu - I have a spare device from H/K which splits one channel into three. Each one can be reversed and slowed.
24 Jan 2019 07:57 #18790 by JRI
Replied by JRI on topic How do I slow them down?
Simon, your Tx 14SG does have a servo slow-down function (I use it on my flaps) and it's under the "SERVO SPEED" chapter on page 83 of the manual. I suspect your new 18 box has even better facilities.
  • Simon O
24 Jan 2019 09:28 #18792 by Simon O
Thanks Kevin, I will try and find the control in my tx as JRI suggests 1st.
Time to create page: 0.375 seconds
