Freewing F14 underpowered
  • Wingman1962
6 years 1 month ago #20702 by Wingman1962
Freewing F14 underpowered was created by Wingman1962
Been doing a lot of head scratching over the problems I'm having with my Freewing F14. Have spent time going through everything I can think of to try and increase the thrust from the twin EDF's but have only managed a small improvement. According to the manufacturer it should be producing over 5000 grams of thrust but I can only achieve just over 3000 grams. Before I start spending money on a power upgrade I thought I would ask if anyone had any suggestions. Its fitted with twin 80mm edf's, two Hobbywing 80amp opto esc's, two 6s 5000mah Turnigy Lipo's. Cheers John
6 years 1 month ago #20703 by MikeSeale
Replied by MikeSeale on topic Freewing F14 underpowered
What is the c rating of your batteries?
Have you tried flying it?
6 years 1 month ago #20705 by 4Pedalsfly
Replied by 4Pedalsfly on topic Freewing F14 underpowered
John - I'm not a ducted fan man but searched " Freewing F14 Tomcat " and came up with a very interesting posting
by " The RC Geek " claims he's the man who flew the prototype.
This used 2 off 6S 30C 5,800 mAh LiPos.
Interesting reading, goes into loads of detail on setting up etc.
Hope this helps.
  • Wingman1962
6 years 1 month ago #20708 by Wingman1962
Hi Colin, thanks for your reply. I have spent literally hours on line researching information about this model and have read reviews and watched videos. This chap from RC geeks has some interesting ideas, 5800 mah packs would be heavier than the lipos that I'm using now which I believe would give a longer flight time but not more power. I have toyed with the idea of fitting 4000mah packs which would be lighter and therefore in theory the model would fly without the extra power. Lots good stuff online tho but no real answer to my problem.
Thanks John
6 years 1 month ago #20709 by DaveBright
Replied by DaveBright on topic Freewing F14 underpowered
As Mike asks... what is the C rating of your current packs?
6 years 1 month ago #20710 by MikeSeale
And I'm asking if you've tried flying it yet because there is no way of knowing whether your method of measuring thrust is comparable to theirs. IOW, you might already have enough thrust and all this tinkering is wasted when you should be out flying it.
