Magnets & 2.4 GHz Receivers
  • 4Pedalsfly
5 years 7 months ago - 5 years 7 months ago #21711 by 4Pedalsfly
Replied by 4Pedalsfly on topic Magnets & 2.4 GHz Receivers
Thanks All for additional comments - pic of final installation attached.
The ferrite ring for the Ubec was supplied loose in the packet so the unwary
could easily omit fitting it, the other ferrite ring is on the E.S.C. lead.
I will check to ensure there are no interference issues before maiden flight.
Last edit: 5 years 7 months ago by 4Pedalsfly.
5 years 7 months ago #21715 by DaveBright
Replied by DaveBright on topic Magnets & 2.4 GHz Receivers
Careful of your Velcro polarisation too. Has to be furry bottom on the receiver otherwise the 2.4Ghz will have a dead spot directly under the receiver.
5 years 7 months ago - 5 years 7 months ago #21717 by JRI
Replied by JRI on topic Magnets & 2.4 GHz Receivers
DaveBright wrote: Careful of your Velcro polarisation too. Has to be furry bottom on the receiver otherwise the 2.4Ghz will have a dead spot directly under the receiver.
Or use a "furrite" ring to neutralise any stray "velcrons" :dry:
Last edit: 5 years 7 months ago by JRI.
5 years 7 months ago #21721 by kevinross
Replied by kevinross on topic Magnets & 2.4 GHz Receivers
"Velcrons" - thats a whole new subject but at least they have Wings and Antennae
shishenyunewworld.wordpress.com/velcrons/
  • 4Pedalsfly
5 years 7 months ago #21723 by 4Pedalsfly
Kevn - Thanks for the "Velcron" update - my garage is both dark & moist - guess I need some
anti-Velcron spray to protect my models against possible infestation.
5 years 7 months ago #21727 by Phil Ford
Replied by Phil Ford on topic Magnets & 2.4 GHz Receivers
Best policy is to isolate the two animals. Keep Vel (velour) in another room from Cro (crochet). Also keep the plastic sheet between them, this will stop any unintentional clinging on or reproduction. Only bring them together when absolutely necessary. I believe that there are other similar creatures known as 'ook n loop usually living in or found in Yorkshire
Time to create page: 0.286 seconds
