Unmarked ESC
  • Brian Jackson
15 May 2021 19:11 #24660 by Brian Jackson
Unmarked ESC was created by Brian Jackson
I have an ESC which is a plain black heatshrink covered item. Is there a way of finding out its rated Amps? Apart from loading it until it blows up.
  • Mike Seale
16 May 2021 09:14 #24661 by Mike Seale
Replied by Mike Seale on topic Unmarked ESC
Size/weight of an ESC is directly proportional to its current rating. Check the weights of a few different ESCs online and then compare to work out your approximate rating.
Also, most of us generally use a bigger ESC than we need. If the system draws 30A we will use a 40A ESC, for example. But most ESCs can take a lot more abuse than that.
Finally, ESCs are relatively cheap and if you do burn your unbranded controller it won't cost much to replace it in the future.
Time to create page: 0.231 seconds
