AR900 Wing INAV
21 Nov 2021 12:08 - 21 Nov 2021 12:09 #25391 by Phil Ford
AR900 Wing INAV was created by Phil Ford
Thursday was an overcast day with little or no wind. had a few flights with the Wing. It is only 900 mm wing span and black. Not the best of colours I suspect on a grey to dark grey sky. Anyway on the last flight which was about 3pm and getting dismal I flew it round a bit for the benefit of the HD Cam, then placed in loiter Mode so it would circle around the GPS position at a preset radius.
I then switched back to manual and decided go a lot higher for more views. It was getting really small now but I could see the strobe on the underside. The strobe started to get fainter and thought this is way way out. Now the UAV is not really visible but it was still within control range according to the RSSI feed. Thinking, how to fly something that is a dot or less. Eureka! Click RTH. After what seemed eternity here it comes, cruising along at 40 metres altitude and began it's circle above the far side of our field where it had been Armed.
In fact it WAS a long way out as can be seen in the image below and the GPS Data The burial mound in the far centre of the next field to the field adjacent to our strip is where it got too before RTH.
Last edit: 21 Nov 2021 12:09 by Phil Ford.
22 Nov 2021 23:43 #25392 by DavidTappin
Replied by DavidTappin on topic AR900 Wing INAV
Is that really the curvature of the earth?!
23 Nov 2021 09:06 - 23 Nov 2021 09:09 #25393 by Phil Ford
Replied by Phil Ford on topic AR900 Wing INAV
If it was David I must have been at 39,000 ft.:lol: No, it is the wide angle lens that gives that effect at distance. Looks impressive though!
Last edit: 23 Nov 2021 09:09 by Phil Ford.
23 Nov 2021 10:45 #25394 by C.Morris
Replied by C.Morris on topic AR900 Wing INAV
You need to fly this FPV!!!
23 Nov 2021 16:24 #25395 by Phil Ford
Maybe Chris. Crash is inevitable. ;)
23 Nov 2021 17:09 - 23 Nov 2021 17:10 #25396 by C.Morris
But you have INAV, it will practically fly by itself!!! No excuse!! :evil:
Last edit: 23 Nov 2021 17:10 by C.Morris.
24 Nov 2021 09:14 - 24 Nov 2021 09:15 #25398 by Phil Ford
:lol: Airbus 320 Fly by Wire flies itself but you still need pilots who know what they are doing. :P Have that in mind when you swan off to Spain on hols
Last edit: 24 Nov 2021 09:15 by Phil Ford.
