AR900 Wing INAV
3 years 10 months ago - 3 years 10 months ago #25391 by Phil Ford
AR900 Wing INAV was created by Phil Ford
Thursday was an overcast day with little or no wind. had a few flights with the Wing. It is only 900 mm wing span and black. Not the best of colours I suspect on a grey to dark grey sky. Anyway on the last flight which was about 3pm and getting dismal I flew it round a bit for the benefit of the HD Cam, then placed in loiter Mode so it would circle around the GPS position at a preset radius.
I then switched back to manual and decided go a lot higher for more views. It was getting really small now but I could see the strobe on the underside. The strobe started to get fainter and thought this is way way out. Now the UAV is not really visible but it was still within control range according to the RSSI feed. Thinking, how to fly something that is a dot or less. Eureka! Click RTH. After what seemed eternity here it comes, cruising along at 40 metres altitude and began it's circle above the far side of our field where it had been Armed.
In fact it WAS a long way out as can be seen in the image below and the GPS Data The burial mound in the far centre of the next field to the field adjacent to our strip is where it got too before RTH.
Last edit: 3 years 10 months ago by Phil Ford.
3 years 10 months ago #25392 by DavidTappin
Replied by DavidTappin on topic AR900 Wing INAV
Is that really the curvature of the earth?!
3 years 10 months ago - 3 years 10 months ago #25393 by Phil Ford
Replied by Phil Ford on topic AR900 Wing INAV
If it was David I must have been at 39,000 ft.:lol: No, it is the wide angle lens that gives that effect at distance. Looks impressive though!
3 years 10 months ago #25394 by C.Morris
Replied by C.Morris on topic AR900 Wing INAV
You need to fly this FPV!!!
3 years 10 months ago #25395 by Phil Ford
Maybe Chris. Crash is inevitable. ;)
3 years 10 months ago - 3 years 10 months ago #25396 by C.Morris
But you have INAV, it will practically fly by itself!!! No excuse!! :evil:
Last edit: 3 years 10 months ago by C.Morris.
Time to create page: 1.606 seconds
