Wrong Fan
18 Jan 2022 14:22 #25481 by Phil Ford
Wrong Fan was created by Phil Ford
Some while ago I had to replace the 12 blade edf in the Stinger which uses 4 cells. I had not used the Stinger for a while so a few weeks ago I gave it a flight or NOT. 3/4 throttle and it just powered itself into the runway snapping off the nose - again. Disgusted I lobbed it into the garage to gather some cobwebs. Being a bit cold lately to go out I repaired the nose section and led. With the wing off I found a 5 blade fan! How did that get there? No wonder it would not fly. The blades were probably spinning so fast on 4 cells that they were actually stalling. However, it now has a 12 blade fan again. At the time of the error I may have suffered ARADS. If it was not ARADS then maybe I should post this in "Stories of Stupidity" :lol:
18 Jan 2022 14:48 #25482 by JRI
Replied by JRI on topic Wrong Fan
Atacama Rover Astrobiology Drilling Studies?
18 Jan 2022 15:27 #25483 by superadmin
Replied by superadmin on topic Wrong Fan
Nope! Age Related Attention Deficit Syndrome. :ohmy:
18 Jan 2022 17:30 #25484 by JRI
More like "Another Real Ale Drinking Session"!
18 Jan 2022 17:30 #25485 by 4Pedalsfly
Replied by 4Pedalsfly on topic Wrong Fan
Recently I replaced the motor on my Modified Hacker " HotWing".
It was easier to work with the model upside down on the bench and 2 thrust adjustment shims marked "Top" & "Bottom"
we're refitted.
Yes - You've guessed it.
With the model the right way up
shims in wrong place.
Motor out & shims refitted.
Another case of ARADS.
Colin.A
19 Jan 2022 10:44 #25486 by Phil Ford
Replied by Phil Ford on topic Wrong Fan
I did not want members to think I had a drink problem so I used the other excuse
