Hobbywing ESC Set-Up
11 Sep 2012 11:00 - 11 Sep 2012 11:28 #3 by Phil Ford
Hobbywing ESC Set-Up was created by Phil Ford
Attachment hobbywingbox_pro.jpg not found
Hobbywing have now a easy way to set up your ESC without the use of tones and your stick movement. Using a small black box , Hobbywing 2 in 1 Pro, about the size of cigarette packet, it is plugged in to the ESC, connect a 4 cell dry battery supply of 4.8v and then scroll through the menus and se tup the ESC.
Click save and the ESC is programmed. The hardware in the unit can be upodated using your PC (USB lead provided) You even prgram your ESC using your PC by down;laoding the relevant driver! :)
Last edit: 11 Sep 2012 11:28 by Phil Ford.
