Lipo battery
  • christopher
20 Jul 2015 20:48 #5210 by christopher
Lipo battery was created by christopher
Help I have a lipo battery which expands when used it seems like gas when it cools it's fine ( I'm not happy with it) 2 questions first is it safe second if it's not how do I dispose of it
20 Jul 2015 20:55 #5211 by MikeSeale
Replied by MikeSeale on topic Lipo battery
IMHO, all LiPo's will do this eventually. How soon depends on how well you treat them in terms of charging, storage and discharging. When they start to go most of us will probably continue to use them for a while and we make our own decision as to when 'enough is enough. Sounds like you've reached that point!
For disposal. Fill a bucket with enough water to cover the battery and add a good amount of salt. Then add the battery and leave it there for several days. When you're done, the battery can be thrown away in the domestic waste and the water is also safe to pour down the sink.
20 Jul 2015 23:48 #5213 by 4Pedalsfly
Replied by 4Pedalsfly on topic Lipo battery
MikeSeale wrote: IMHO, all LiPo's will do this eventually. How soon depends on how well you treat them in terms of charging, storage and discharging. When they start to go most of us will probably continue to use them for a while and we make our own decision as to when 'enough is enough. Sounds like you've reached that point!
Chris - When discharged I always cut the power & balance leads off - can come in handy later.
I dispose of mine at Milhams Tip where they have a large metal container for batteries.
Colin. A
21 Jul 2015 07:44 #5216 by MikeSeale
4Pedalsfly wrote: When discharged I always cut the power & balance leads off - can come in handy later.
Colin. A
I would not recommend cutting off the connectors if you're going to throw them in a metal container!...unless you have already discharged it completely in salt water.
21 Jul 2015 10:27 #5219 by Phil Ford
Replied by Phil Ford on topic Lipo battery
christopher wrote: Help I have a lipo battery which expands when used it seems like gas when it cools it's fine ( I'm not happy with it) 2 questions first is it safe second if it's not how do I dispose of it
As Mike says, they all do it eventually. When they don't fit in the bay anymore or power is down you'll know. That's the time to replace. Some I have treated badly and they have not expanded. On the other hand, some handled with tender loving care and last five flights then fatten up.... :lol:
Salt water discharge? LiPos in submarines a no go then? Maybe that's the Russian submariner's problem. :silly:
