fw 190
04 Feb 2016 16:45 - 04 Feb 2016 16:50 #7910 by flyingpete
fw 190 was created by flyingpete
Deleting some pic's on my phone and found this pic !
I bought this model last year for £200 from hobby king! Not bad i thought comes with all servos and retracts just add batt and rx .
Must get up to cashmoor and give this bird her maiden and while i'm at it get some stick time on the panther :woohoo:
63" span and 6s lipo 4000 mah
Last edit: 04 Feb 2016 16:50 by flyingpete.
05 Feb 2016 18:35 #7914 by simondean
Replied by simondean on topic fw 190
Looks pretty good, will join you in the air for WW2 action soon with P 47
06 Feb 2016 10:52 #7916 by Phil Ford
Replied by Phil Ford on topic fw 190
I got two foamie Muzzies from the same place, Pete and same maker. FMS? One is Red (Century UK) and the other is the Gunfighter version.(FMS). Taking off needs decent ground speed at least, landing not a an issue except for the crap retracts. Plastic swivel pins!
Replaced mine with E-Flites. See my article on the Dago Red Mustang. CG is a bit touchy too. Had to ignore the manual recomms and work it out myself.
06 Feb 2016 13:32 - 06 Feb 2016 13:41 #7918 by flyingpete
Replied by flyingpete on topic fw 190
The retract unit's will be fine as they are all metal! the weak link on this model will be the scale oleo legs which are quite flimsy.Depending on how well it fly's i might swap them for something stronger.
As for the c of g i must agree! Iv had to put a rake of lead in the nose to get it any where near a safe position for a test flight :(quite normal though with a ww2 fighter with it's very short nose.
Last edit: 06 Feb 2016 13:41 by flyingpete.
