ESC Capacitors
06 Apr 2016 16:56 #8536 by Chris001
ESC Capacitors was created by Chris001
I just noticed some thing a little odd with one of the capacitors on an ESC.
The capacitor leg next to the negative wire has broken, I suspect that this happened over time through repeated plugging and unplugging of the battery causing the negative lead catching the top of the capacitor and put strain on the leg.
It's going to be easy enough to fix, but would have gone unnoticed had I not seen the capacitor move when I was looking over the battery connector.
I have been using HXT connectors in which the positive and negative connectors are housed in a common plastic surround. I think this naturally requires more force to plug and unplug and also pulls the ESC battery leads in together which transfers any of the leads movement onto the capacitors. I've decided to split all my remaining HTX leads.
06 Apr 2016 21:41 #8544 by 4Pedalsfly
Replied by 4Pedalsfly on topic ESC Capacitors
Chris - If possible you could consider anchoring the connector to the fuselage thus taking
all the stress off the e.s.c leads.
Colin. A
Time to create page: 0.247 seconds
