Frank's Mustang 40 Gets More Power
14 Jun 2016 16:28 - 14 Jun 2016 16:31 #9032 by Phil Ford
Frank's Mustang 40 Gets More Power was created by Phil Ford
Here you go Frank.
Cashmoor. Tuesday 14th June. Random heavy showers, wind about 13mph gusting up to 23. Dark threatening clouds so not an ideal day for the silver grey Mustang flight. Assembled by the late Frank Robinson but never got flown. A bit of rewiring was required. Maiden showed it was under powered so I swapped out the motor for a SK3 5045 660kv (ex Wots Wot). Used the original Wots battery a 5 cell giving about 1000 watts WOT on 13 inch prop. Flies a lot better now even in high winds. Two attempts to land but a succesful touchdown . Found it really needs full rate elevator to stop nose over on touchdown. I might at a later date drop in a 6 cell and reduce prop to 11 inch which would should give about 1350 watts.
The Curare had no issues at all in the weather conditions. :)
Last edit: 14 Jun 2016 16:31 by Phil Ford.
14 Jun 2016 17:10 #9033 by JonTappin
Replied by JonTappin on topic Frank's Mustang 40 Gets More Power
Nice touch with the pilot name Phil :)
14 Jun 2016 17:30 #9034 by Phil Ford
Replied by Phil Ford on topic Frank's Mustang 40 Gets More Power
JonTappin wrote: Nice touch with the pilot name Phil :)
It was already on there Jon... ;) There is also four successful enemy downs on the otherside. :lol:
14 Jun 2016 19:22 #9035 by 4Pedalsfly
Replied by 4Pedalsfly on topic Frank's Mustang 40 Gets More Power
Brave man to go fly today, I looked at weather this morning and decided it was a no go.
Pleased the day went well for you.
Colin.A
