Pull pull rudder
  • tommy
06 Jul 2016 15:13 #9201 by tommy
Pull pull rudder was created by tommy
Just a quick question. I'm building a large electric sukhoi 26. Do you guys generally cross the pull pull wires between servo and rudder control surface ? Very mixed opinions online. I'm thinking of crossing them as geometry seems better but will this not produce excessive chaffing of wires ? Thanks
06 Jul 2016 15:27 #9202 by Chris73
Replied by Chris73 on topic Pull pull rudder
I have always crossed them, unless the instructions say not to, if the geometry looks better crossed then i would definitely cross them
Never had an issue with the wires chaffing as they tend to be nylon coated anyway
06 Jul 2016 16:10 #9204 by flyingpete
Replied by flyingpete on topic Pull pull rudder
Yes defo cross them! As Chris said they are plastic coated and for spot on geometry the servo arm should be the same width as the rudder horn
  • tommy
06 Jul 2016 17:37 #9205 by tommy
Replied by tommy on topic Pull pull rudder
Thank you both, good to get some reassurance.
Time to create page: 0.255 seconds
