Simon!
  • Dave Rogers
  • Premium Member
  • Premium Member
09 Aug 2016 20:27 #9585 by Dave Rogers
Simon! was created by Dave Rogers
Simon,
Could you take a look at your ripmax mustang motor again for me and tell me the numbers on it when you have a chance, I forgot from when we looked on Saturday, what an idiot! Also the prop size you using?
Cheers, want to get one ordered.
Dave
10 Aug 2016 19:30 #9593 by 4Pedalsfly
Replied by 4Pedalsfly on topic Simon!
Dave - If it's the 1,200 mm a.r.t.f one, I fly mine on a EMax GT 2815/07 -. 1,100 kV - 400 W - 5 mm shaft
with 11 x 7 APC prop.
Hope this helps.
11 Aug 2016 08:16 #9596 by simondean
Replied by simondean on topic Simon!
Hi Dave , sorry for the delay. My motor is a Overlander Thumper V2 T3536/05 530 watt. KV 1520. 40--60 A esc 2--3 lipo
Prop I have is APC 10x7
Should be enough info to get something similar on HK ? As I know this is your preferred supplier ;)
11 Aug 2016 10:00 - 11 Aug 2016 10:03 #9599 by Phil Ford
Replied by Phil Ford on topic Simon!
Dave, take a look at my Ripmax Mustang article especially the update 2014. That is my current set up. I do have a spare Emax 2820 if you want it. On 4 cells give you 600 watts.....wooooo!
Last edit: 11 Aug 2016 10:03 by Phil Ford.
  • Dave Rogers
  • Premium Member
  • Premium Member
12 Aug 2016 15:10 #9608 by Dave Rogers
Replied by Dave Rogers on topic Simon!
Thanks all, Simon all ordered, thanks for your efforts :)
