Mode 1 or 2
  • John Bannister
  • Senior Member
  • Senior Member
27 Apr 2018 19:45 #16421 by John Bannister
Mode 1 or 2 was created by John Bannister
I have a friend who wants to start flying again after a long break He was taught mode 1 Is it a good opportunity to switch to mode 2 or best to stick with mode 1
27 Apr 2018 20:50 #16422 by Chris73
Replied by Chris73 on topic Mode 1 or 2
Personally I do not think either mode has an advantage over the other, so if he was taught to fly mode 1 I would stick to that
27 Apr 2018 21:19 #16423 by MikeSeale
Replied by MikeSeale on topic Mode 1 or 2
If he needs someone to help fly his plane using his transmitter than he might consider converting to mode 2. But most modern transmitters can buddy box a mode 1 with a mode 2 transmitter so this should not be necessary except that...
His mode 1 transmitter will have the model memory and trim settings and this would usually be the master transmitter...
...and he would normally be holding the slave transmitter.
So someone would have to go to the effort of copying across his model setup...probably quite easy with SD cards
That said, he will probably not need buddy boxing because he will remember how to fly almost straight away
27 Apr 2018 22:02 #16424 by 4Pedalsfly
Replied by 4Pedalsfly on topic Mode 1 or 2
Hi John - First question is what brand of transmitter does he have, if it's Spectrum then you coulld bind your Mode 2 tx to
his model & buddy lead him with his Mode 1 tx.
You probably recall I fly Mode 1 so I could help him out.
I'll chat next time we meet at the field.
