A Tidy Switch Install?
18 Nov 2016 16:27 - 18 Nov 2016 17:18 #10796 by Phil Ford
A Tidy Switch Install? was created by Phil Ford
Thinking on how to reduce too many holes for switches in Pepsi. On my other petrol planes they have a main switch for RX power and another switch for ignition and using a LIFe battery pack for Rx and NiMh/LiFe for ign.
To reduce the number of switches I am thinking that whilst there is no main power for RX/servos the Opto kill switch will also keep the ignition off. I would imagine the Opto Kill draws a tiny amount of current even when "off" but not an issue for a days flying. Use kill switch on TX whilst priming. Feasible?
What set up do you other gasser Guys use?
Last edit: 18 Nov 2016 17:18 by Phil Ford.
18 Nov 2016 18:19 #10798 by JRI
Replied by JRI on topic A Tidy Switch Install?
I never fit a physical switch to by opto circuit. The off leakage current is negligible.
18 Nov 2016 18:50 #10799 by Phil Ford
Replied by Phil Ford on topic A Tidy Switch Install?
Thanks John. You just plug in the ignition battery direct at the start of the day then?
18 Nov 2016 19:24 #10801 by JonTappin
Replied by JonTappin on topic A Tidy Switch Install?
I do the same Phil, no separate ignition switch. I do unplug my batteries when not in use though
18 Nov 2016 19:28 #10802 by Phil Ford
JonTappin wrote: I do the same Phil, no separate ignition switch. I do unplug my batteries when not in use though
Cheers Guys. One switch it is then..... :)
