ROTO Engine Carb, Worbro
  • simonbloke
11 Jun 2017 08:48 #13067 by simonbloke
ROTO Engine Carb, Worbro was created by simonbloke
Hi Guy's.
Need a bit of help with the carb, engine will not draw fuel from tank.
Taken carb off, can't blow into fuel inlet, Blocked ?
Remove casing with inlet tube on it one screw, can then blow into inlet tube, can see the little valve, paper flap, that,s opening and closing as i blow.
Refit casing, can't blow in ?!... umm...remove low and high speed jets counting turns open throttle, still cant blow through fuel inlet tube....
Ummmmm....Help
Any advice would be appreciated
Simon
11 Jun 2017 10:49 - 11 Jun 2017 10:49 #13068 by kevinross
Replied by kevinross on topic ROTO Engine Carb, Worbro
Hi simon
A likely cause will be the carb valve/s stuck - 3 options
1 - pressurise the fuel feed while flicking the engine
2. - remove plug and prime the engine - When it fires, the increased crankcase pressure pulses may kick start the pump
3. - Remove the carb side with the single screw and unstick the pump flaps
Last edit: 11 Jun 2017 10:49 by kevinross.
  • simonbloke
11 Jun 2017 12:20 #13069 by simonbloke
Replied by simonbloke on topic ROTO Engine Carb, Worbro
Thanks, did that and removed the needle valve on the other side, cleaned refitted.
Now it sucks up fuel on engine rotation....Yippee, stuck needle valve i think
fiddly or what !!
Ta
Simon
11 Jun 2017 13:09 #13070 by kevinross
From now - always keep the fuel system wet. store with about 1/4 tank.
have a look at this document to understand the Walby Carby
  • simonbloke
11 Jun 2017 15:23 #13071 by simonbloke
Thank you very much
Simon M
Time to create page: 0.538 seconds
