Prop Drilling
17 Aug 2018 18:46 #17415 by Chris73
Prop Drilling was created by Chris73
Has anybody got a pillar drill and a 6.1mm drill bit that could drill a prop for me this Sunday??
Thanks
Chris
17 Aug 2018 19:59 #17419 by JRI
Replied by JRI on topic Prop Drilling
Pillar drill yes, would have to check for 6.1 but have plenty of 6.0 and 6.5 (nb 6.1 is only 4 thou bigger than 6.0 and likely to be the result of a less than perfect 6.0 anyway). Also have guides for many 6 and 4 bolt props.
17 Aug 2018 20:20 #17421 by JRI
PPS I have plenty of timber for dummy runs before comitting the real prop!
17 Aug 2018 20:32 #17422 by Chris73
Replied by Chris73 on topic Prop Drilling
Thanks John, any chance I could pop round Sunday ?
17 Aug 2018 20:42 #17424 by kevinross
Replied by kevinross on topic Prop Drilling
More than willing to help Chris but i'm a long way out for you.
17 Aug 2018 20:51 #17425 by Chris73
Thanks Kevin, hopefully John can help me out
17 Aug 2018 21:21 #17426 by JRI
PM'd you Chris - come round any time Saturday eve or Sunday.
18 Aug 2018 08:29 #17429 by DavidTappin
Replied by DavidTappin on topic Prop Drilling
1/4" is only 10 thousands of an inch more than 6.1 mm which is the hole size you would be likely to end up with using a badly sharpened 6.1 mm drill!
18 Aug 2018 09:09 #17430 by JRI
DavidTappin wrote: 1/4" is only 10 thousands of an inch more than 6.1 mm which is the hole size you would be likely to end up with using a badly sharpened 6.1 mm drill!
Ther are 40 thou in a mm so the diference between 6.0mm (nominal bolt size) and 6.35mm (1/4") is only 14 thou'!
I agree with Dave, go for 1/4" or even 6.5mm otherwise swelling wood or tiny discrepencies in the drill guide will cause sticking bolts and consequent stripped threads in the hub. I think I have drilled out my guides to 6.5mm anyway so no point in trying for better unless you use a huge mill/drill and a dividing-head.
Time to create page: 0.320 seconds
