O.S. FX glow engine advice
7 years 3 weeks ago #17772 by Phil Ford
Replied by Phil Ford on topic O.S. FX glow engine advice
MikeSeale wrote: Yoda reference Phil doesn't get.
No!
Quikfil valve rubbers are fuel sensitive. Glow for glow and petrol for petrol. Not anything else. ;) Red colour for petrol, Silver for glow. I found out a long time ago petrol eats the rubber of glow versions. Caused engine troubles with intermittent cutting out.
7 years 3 weeks ago #17788 by
Replied by on topic O.S. FX glow engine advice
Slight problem for me then Phil. The valve body on the models cowl is RED. It's a glow engine!
7 years 3 weeks ago #17789 by JonTappin
Replied by JonTappin on topic O.S. FX glow engine advice
You might be OK Simon, usually using glow parts for petrol is a problem because the petrol damages the o ring rubber, you might be OK the other way round.
Either that or just remove it completely and use another fill method
7 years 3 weeks ago #17790 by
Thanks Jon. I will replace the petrol Dubro unit with a glow version before I go any further. As far as I know, the motor ran fine when it was last used so as you say I might be ok.
7 years 3 weeks ago #17795 by Phil Ford
You may get away with it but if the O ring leaks in air then you don't get the pressure to push the fuel to the carb. Also the centre button sticks when getting old and then the same problem. Because I was wary of this issue although rare it happened to me. I only have one in use now and that's on a petrol motor. All the glow motor Quikfil have been returned to the good old fuel dots.
Time to create page: 2.103 seconds
