Ignition timing
07 Jan 2019 21:13 - 07 Jan 2019 21:16 #18606 by kevinross
Ignition timing was created by kevinross
Santa brought me a CDI tester so have made an adapter to fit std NGK M10 x1 thread to determine accurate TDC using a DTI - so contact me if you need to check an engines static timing.
Last edit: 07 Jan 2019 21:16 by kevinross.
The following user(s) said Thank You: DaveBright, Phil Ford
08 Jan 2019 08:51 - 08 Jan 2019 08:52 #18612 by Phil Ford
Replied by Phil Ford on topic Ignition timing
Mercer Gauge! Haven't seen or used one of those for decades after I lost interest in rebuilding car petrol/diesel engines
Last edit: 08 Jan 2019 08:52 by Phil Ford.
Time to create page: 0.419 seconds
