Walbro needle adjustment
23 Apr 2019 22:54 #19374 by kevinross
Walbro needle adjustment was created by kevinross
Although walbro needle adjustments are rare, on some models it can be a pain when the carb is buried deep in the cowl. Ive modified this carb by turning a shoulder on the needle then soldered some 5mm brass tube. This will enable a driver to be inserted at rest and safely adjusted from behind the wing with engine running.
If any of you petrol heads can't get your driver in the slot - bring me your needles for the operation - it wont hurt !
The following user(s) said Thank You: JRI, Phil Ford
24 Apr 2019 09:31 #19376 by Phil Ford
Replied by Phil Ford on topic Walbro needle adjustment
i did try forcing on some warmed up Sullivan snake outer. Problem was the thickness of the snake bound against the adjoining needle so gave up. ;)
Time to create page: 0.239 seconds
