MDS 40
  • PhilG
06 Aug 2019 21:08 #20499 by PhilG
MDS 40 was created by PhilG
I have just bought an un-run MDS 40 2-stroke on Ebay for £30. Also, I have been reading some forum topics on MDS engines (generally from some time ago when they were available). There was a majority subscribing to the view "... they're junk ..." but also some who thought they were great!
I have put through 3 or 4, 4oz (110ml) tanks full on a running in regime and it has become much better over that time but still not reliable enough to commit to a plane.
The biggest problem seems to be throttling up to max speed from a period on idle or a bit above (4-stroking).
I would appreciate any advice or comments with regard to the engine and it's settings.
Thanks,
Phil.
06 Aug 2019 22:34 #20500 by Brian
Replied by Brian on topic MDS 40
Hi Phil, I had one a few years ago, at the time, "MDS" was reckoned to stand for Metal Door Stop. My engine was OK at starting, but throttling was unreliable. Finally I took the problem to Just Engines, they recommended one of their twin needle carburettors. After swapping the original carb for the J'EN one, the engine was transformed. I can only say that the MDS .40 was the easiest starting and the most flexible running two stroke i ever had. I don't know if Just Engines still have a suitable carburettor, but it would be a good place to start.
  • PhilG
08 Aug 2019 19:28 #20511 by PhilG
Replied by PhilG on topic MDS 40
Thanks Brian,
The more running in it gets, the better it becomes. I note in the instructions they recommend not adjusting the low speed needle until at least 3 hours of running./ I'm not there yet and I'll see how it is then before looking to change the carb. Thanks for the advice re Just Engines; I have found them very good in the recent past.
Kind regards,
Phil.
09 Aug 2019 06:11 #20512 by Brian
Engines do tend to improve during the first hours of running. My MDS was an early model from RipMax(I think). Initially, the throttle response was so erratic, I locked the throttle open, sleeved the intake, and used the engine in a control line model. The final cure was the J'EN carburettor, the engine is now in a Gangster "somewhere in the South of England". The last I heard of it, it needed two flicks to prime and one flick to start. The new owner never uses an electric starter.
09 Aug 2019 07:40 #20513 by DaveBright
Replied by DaveBright on topic MDS 40
I had an MDS 58 in a .40 sized propjet. Never had any problems and with stock carb. Probably a later variant though.
