New to glow engine
6 years 1 month ago - 6 years 1 month ago #20704 by
Replied by on topic New to glow engine
So will I need to invest in a on board glow heater for it run good or will be ok how it is ?? And yes looking forward to flying i/c planes .. just got to save some cash and invest in some gear to get it running
Last edit: 6 years 1 month ago by .
6 years 1 month ago #20706 by Phil Ford
Replied by Phil Ford on topic New to glow engine
No, you don't need an onboard auto glow unless you cannot achieve a reliable idle. Fly it first! No need to spend money willy nilly. ;)
6 years 1 month ago #20707 by JonTappin
Replied by JonTappin on topic New to glow engine
Hi Dan
I wouldn't bother to go with an onboard glow yet if it was me. I've run lots of inverted glow engines in the past and have never needed to. I would try it without and then if you do have issues that can't be solved with proper tuning, then consider it later.
The main issue with inverted 2 strokes is with starting, as if it is too wet it can put the glow plug out and even hydraulic lock if it's really wet. Starting with the model upside down or on its side with the exhaust down makes this easier. On board glow obviously does not help with this!
Time to create page: 0.223 seconds
