Biplane flying wire separator or Javelins.
20 Sep 2020 22:15 - 20 Sep 2020 22:21 #23345 by kevinross
I made a pair of triangular shaped jigs to match the flying wire crossover angle, then marked the wire positions. Next i glued strips to guide a mini hacksaw blade to cut some carbon tube
Last edit: 20 Sep 2020 22:21 by kevinross.
20 Sep 2020 22:20 #23346 by kevinross
Replied by kevinross on topic Biplane flying wire separator or Javelins.
Then i cut approx 3/4 thru the tube to allow the wire pass beyond a central pin . The central pin is M2 threaded rod which is secured by threaded nylon bullets. I made the bullets from Nylon pc board standoffs.
Now its time to find out if they work !
21 Sep 2020 08:54 #23350 by Phil Ford
Replied by Phil Ford on topic Biplane flying wire separator or Javelins.
I wondered or could not remember what the things were that sat on the cross-over of the flying wires. Thanks
