Unknown Glow Engine
04 Mar 2021 14:25 #24314 by Phil Ford
Unknown Glow Engine was created by Phil Ford
Tidying the garage and came across this little engine. Made in Austria. Capacity? One hell of a compression. Brass cylinder liner. I vaguely remember getting this thing running years n years ago. I think it is too big for Control Line. What is it?
04 Mar 2021 18:30 #24315 by ruggerbloke
Replied by ruggerbloke on topic Unknown Glow Engine
Phil, I think it's a Weston of some capacity. They appear to be made in Austria.
www.westonuk.co.uk/West-Eurotech-Aero/
05 Mar 2021 09:02 #24319 by JRI
Replied by JRI on topic Unknown Glow Engine
Weston engines are/were based on Webra crankcases - hence the "Made In Austria" logo.
05 Mar 2021 10:14 - 05 Mar 2021 10:14 #24320 by Phil Ford
Replied by Phil Ford on topic Unknown Glow Engine
It could possibly go into a Mini Magnum or something similar I suppose. Although after watching the two Dave's Weston antics what seems like ages ago maybe not. :lol:
Last edit: 05 Mar 2021 10:14 by Phil Ford.
05 Mar 2021 16:23 #24322 by 4Pedalsfly
Replied by 4Pedalsfly on topic Unknown Glow Engine
Phil - This may help - HP engines were manufactured in Austria by Hirton Berger AG .
They were top rated engines in
the 1970's .
Yours looks like it may be a car or Heli version.
Are there any other markings on the crankcase ?.
A pic on the BMFA website may confirm Identity .
05 Mar 2021 17:14 - 05 Mar 2021 17:19 #24323 by Phil Ford
I remember now how I got it. Dave B was offloading a load of odds n sods to help buy his first BAe Hawk turbine. ;) I got sucked into buying a home built little balsa red jet thingy and this engine was attached to it. The air-frame was not in good order so years later it got binned but the engine was removed. I think it is a Weston 36 and the pipe is a Cougar. It could go into the Mini Magnum. I fitted it to my glow engine test bed and got it running. The first prop was 8 inch but the piece of wood aka chicken stick, I was using to flick it chipped it badly. Found another glow prop, a bit big at 11x7 but it fitted. Runs quite nice actually and surprisingly quiet too until high throttle where the overly large prop bogs it down.
Strangely around the same time years ago I also bought off Dave a DLE55 which never saw an aeroplane till 2019. I think it was removed from an SBach that was sold airframe only. Funding entry to turbines I suspect. The DLE55 sat in a carrier bag in the corner until I built the Pitts S2 and it runs really good. :)
Last edit: 05 Mar 2021 17:19 by Phil Ford.
05 Mar 2021 17:48 #24324 by DaveBright
Replied by DaveBright on topic Unknown Glow Engine
Hi Phil,
Few things.... that little Hawk was entirely flyable! You just didn’t! :-)
The engine is a West 36 t1 with throttle pipe. It’s designed for aerobatic and good throttle response not to have its nads revved off, that’s the V1 range which are suited to high rpm which is why they’re used for the magnum.
You refer to a cougar, that was a fun fly airframe designed by Weston uk.
I can’t remember what I was funding at the time :-)
I don’t recall what the DLE 55 came out of.... possibly the Sbach but I was sure I had a DA in that.
Anyway, stick it in something little, light and fun fly- ee.
05 Mar 2021 19:27 #24326 by DaveBright
11 years ago!
06 Mar 2021 10:14 #24327 by Phil Ford
Dave Bright wrote: 11 years ago!
Flippin' 'ell! :ohmy: Does'nt time fly by?
07 Mar 2021 15:46 #24330 by DaveBright
Not sure what it was funding. The first big Hawk wasn’t until 2014. First turbine was 2005!
