Bucker Jungmeister re -engine
07 Jun 2021 21:50 #24761 by kevinross
Bucker Jungmeister re -engine was created by kevinross
Ive replaced the Saito 33cc 3 cylinder with their 30cc single leaving a large gap and a loss of 200grms nose weight. The kit came with disgusting plastic moulding.
I had a 3D printed 9cylinder of the correct size so have cut into sections and rebuilt into a 7 segments to match the cowl.
07 Jun 2021 21:54 #24762 by kevinross
Replied by kevinross on topic Bucker Jungmeister re -engine
continued
I used these ferrules to simulate the spark plugs and used some old audio cables to simulate the HT leads.
The following user(s) said Thank You: 4Pedalsfly, DavidTappin, Phil Ford
08 Jun 2021 09:45 #24764 by JRI
Replied by JRI on topic Bucker Jungmeister re -engine
Nicely done Kevin!
08 Jun 2021 09:56 #24765 by Phil Ford
Replied by Phil Ford on topic Bucker Jungmeister re -engine
Nice job Kevin. I had not thought of that - 3D printed cylinders! Could have done with some for my Pitts rather than a blank, black baffle. Oh well.
08 Jun 2021 21:18 #24768 by DaveBright
Replied by DaveBright on topic Bucker Jungmeister re -engine
Shame you had to give up on the Saito Kevin. They sound so good! Mine’s going well in the Sea Fury
Time to create page: 0.573 seconds
