So That Was What It Was!
4 years 3 months ago - 4 years 3 months ago #24878 by Phil Ford
Replied by Phil Ford on topic So That Was What It Was!
Update: Well here is my final view and answer :unsure: on this subject. On Thursday 8th I did a quick noise test with the help of Simon with the GP original "muffler" fitted. Taken at ground level at a distance of 7 metres at WOT = RPM 7650. Prop Falcon 20x8 Front 94db, Sides 90 db, From Behind 86 db. The "bark" from the exhaust at any thing above half throttle is not nice. So, I have decided that at the moment the Extra is NOT flyable. If the OS exhaust is fitted I lose 1000rpm and max out at 6600. An option is to try a 22x10 prop but that might be just too much load, moving in to the 50cc domain here I think. I don't know which way to go for now. :(
Last edit: 4 years 3 months ago by Phil Ford.
4 years 3 months ago #24881 by Chris73
Replied by Chris73 on topic So That Was What It Was!
Tuned pipe :woohoo:
4 years 3 months ago #24882 by Chris73
You said you got the OS exhaust from BMFA, was it new or second hand??
If it was second hand there is a possibility that it is clogged up
4 years 3 months ago #24883 by 4Pedalsfly
Replied by 4Pedalsfly on topic So That Was What It Was!
Phil - General opinion from the pits area confirms your test results.
PLANE TOO NOISY.
4 years 3 months ago - 4 years 3 months ago #24884 by Phil Ford
Chris Hughes wrote: You said you got the OS exhaust from BMFA, was it new or second hand??
Brand new in box Chris.
4 years 3 months ago #24887 by JRI
Replied by JRI on topic So That Was What It Was!
Did you take it out of the box before fitting it Phil ? ;)
